RPU in the Philippines. - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 60
  1. #11
    Aug 2009
    West mids, England.
    200
    King Herald is offline
    Todays project was brakes.
    I have no idea what the MC is off, but it started out with a big booster diaphragm thing on. That is now in the scrap bin, no faggy powered brakes on this bad boy hot rod.
    Then a lever, gas axed from a chunk of 10mm steel plate. I did this ten o'clock last night, out in the street, with the steel G clamped to the garden gate, as my 'shop' is full of hot rod. The neighbourhood kids thought it was great.
    It is actually made from two pieces, welded together half way up the long bit. My scrap pile is getting depleted, down to rag ends now.
    I found an end boss designed for four bar suspension, with poly bushes, so that was grafted in the middle of the lever. And a tube welded into the chassis rail. A 5/8" bolt secures it all good and snug.
    I plan to make a bolt-on foot pedal, to some design of interest at some stage.
    Never make the mistake of thinking that the rut you're in is really a groove.
  3. #12
    Aug 2009
    West mids, England.
    200
    Just a couple of little things done lately, as I've been busy with loads of other stuff.
    Started to glass the body to the stiffening frame:
    Various seat belt mounts welded in:
    Got to work out the doors too, they are pretty basic:
    I got the steering column and Corvair steering spindle splined to suit a Jap U/J, to save messing about welding something onto either shaft.
    That is pretty much as far as it has got now. A whole years work condensed into a ten minute post. It's copied off my build thread on another forum, which is why it may be a bit disjointed.
    I now have five weeks offshore before I get back and carry on with it, but I have a couple of big boxes winging their way over to the Philippines as we speak, all full of hot rod goodies, some wheels, headers, and other bits and pieces.
  4. #13
    Rods 'n' Sods Junkie fugman's Avatar
    Oct 2009
    bury st edmunds
    443
    60
    fugman is offline
    love it , will be watching this one.
    Everything is an interference fit. I interfere with it till it fits!!
  6. #14
    Official RnS Addict vin likes diesel's Avatar
    London
    2,801
    1527
    vin likes diesel is offline
    cool build
    Pro Street Escort... MOT ready.
    Hug Street Morris Oxford mo.... unfinished, on its tenth set of wheels
    Custom truck ..MOT ready
    Dinner ....finished
  7. #15
    Aug 2009
    West mids, England.
    200
    I started bolting stuff together yesterday:
    Bit of a problem, the steering cross link just touches the headlight brackets on full lock, so something needs to be fiddled with there, maybe less steering lock.
    And I think I'll modify the wheels to give less offset, bring them together a bit more. Just need to cut out four welds to release the centres, and hopefully tap them over 1 1/2" and re-weld, but I doubt it will be so easy......
    I need some rear axle bearings, so I can get the back end all together and wheels on.
    Something that has always confused me a bit, but with the hairpins swinging an arc, the leaf spring going up and down at some angle different to the hairpins, steering, and movement all around, how can you tell whether the spring is binding or moving freely within the shackles?
    So, I decided to fire up my trusty drill lathe and remove the shoulders on half of the shackle bushes, so when it is all assembled and loaded up I can visually see whether my hair pin length is adjusted to put the axe in line with the spring. I assembled it, bounced on the suspension a few times, and the spring 'walked along to one end. A tweak on each hairpin rose joint, bounce again, and it is dead centre.
    Yeah, I'm a sad man.
  8. #16
    Aug 2009
    West mids, England.
    200
    Sun was out yesterday, so I fitted the back axles/wheels in place, and rolled it out into the sun whilst I cleaned out the shed.
    Threw one side of the headers on for a look see.
  9. #17
    Rods 'n' Sods Junkie HBomb's Avatar
    Jul 2010
    Gedney Dawsmere, Lincs
    112
    4
    HBomb is offline
    I never knew you was here KH, never get bored of your builds.. Johnny
  10. #18
    Official RnS Addict V8BUNINOVEN's Avatar
    Nov 2010
    conisborough
    790
    232
    V8BUNINOVEN is offline
    great build and an even better place to do it....sooo lucky.
  11. #19
    Official RnS Addict sk8erdave's Avatar
    Northants
    1,297
    117
    sk8erdave is offline
    loving this. id love to see the reactions youll get when you go down the road.
  12. #20
    Jun 2009
    romford essex
    3,020
    1188
    296moon is offline
    Love this, wheels should def come in a bit, I like "walked along to one end" good way to check it ing
    1. Rear wings needed for the Pop RPU...
      By bigyellataxi in forum Stuff - WANTED
      Last Post: 28-04-2009, 06:55
      Last Post: 27-04-2009, 17:47
    3. the village idiots here
      Last Post: 20-04-2009, 21:42
      Last Post: 20-04-2009, 21:34
