Ryan's Ruby
Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 58
Thread: Ryan's Ruby
    May 2012
    whitehaven
    26
    Red~griffin is offline
    Ryan's Ruby
    Before I start this is my first attempt with a rod so please excuse any ignorance on my part and feel free to put your views across. I'm in no rush to finish this build as I have a lot on with the house so progress may be slow.
    i have been thinking about getting a new project for a while but due to having just bought my first house I didn't want to spend too much or have something getting in the way. Having always prefered older cars and liking to support british made, I settled on the idea of an Austin seven. after a few months of looking for the right base I found a car which took my liking it was on ebay but unfortunately i missed the auction whilst being away on holiday. To my luck the winning bidder never turned up to collect the car and it was re-advertised this time I made sure I got it.
    So here's my idea the car is small and very light so where possible I'm going to try and keep the weight down. I would like to keep the original identity so I will be keeping the chassis, suspension and steering original ish. But everything else is up for grabs. I am fully aware that it's not going to handle that well so don't have any desire to throw huge amounts of power at it. But at the same time I'd like it to be quick enough so that I enjoy driving it and that it will keep up with modern traffic. I'd like the roof chopped and the body channeled.
    Thats about it heres some pics of what I'm starting with and my first days progress.
    Official RnS Addict 1stpop's Avatar
    isle of sheppey kent
    2,484
    48
    1stpop is offline
    that looks like a very good start there mate, if you want to keep it light take the engine out of the 2 wheeled beast next to it in last pics , then you dont have to dress up as a power ranger on the bike again.
    but seriously think about what engine you are wanting to use before you commit to using original suspension and steering
    Aug 2010
    herts
    471
    beario is offline
    bike powered seven...now that sounds really good if you decided to do that...
    Turbo 4 pot freak 20vT_pop's Avatar
    Oct 2010
    Suffolk
    1,891
    1249
    20vT_pop is offline
    This is the first time I have seen a seven chassis I can't believe that is all there is to it, I do know the rear axle is very weak so if you are to use it you probably won't want more than about 60bhp maybe a "A" series 1275 engine with morris 1000 or marina gearbox would do or even a reliant 850 engine and gearbox with a little bit of tweaking they can get along pretty nippy, in fact the reliant engine is smaller than the morris engine so that would probably suit it better. This is bearing in mind your choice of keeping it lightweight with std axles steering etc, good luck with it.
    John
    My Pop Build thread https://www.rodsnsods.co.uk/forum/gar...op-build-32191
    My 55 Chevy Resto https://www.rodsnsods.co.uk/forum/tri...ed-today-67186
    Anyone can drive a fast car, not everyone can drive a car fast!!!!
    May 2012
    whitehaven
    26
    I'm going to add gas shocks but so that I can remove them if need arises
    I've already measured up the fireblade engine. The problem with a bike engine is that it sits too far too the passenger side to connect straight to the prop. I could sort this but might add in weakness, I.e one small prop running along side the main connected with a chain and cogs.
    The other option I thought was rover k-series erich keeps with the rover mg austin family and is light and alloy block like the cars original
    I will probably be using a midget rear axle
    Oct 2010
    Suffolk
    1,891
    1249
    20vT_pop is offline
    R1 engines with the stacked gearbox allow the prop to run much straighter, I have a turbo blackbird engine in my westfield I run a split prop and have had no prop problems with wear or balance and I get well over 350bhp at the wheels, but unless you do some radical stuff to the suspension or steering I would have thought the bike engine would have been far too radical for safe use, it will get a serious tramp on and you know you will use it, cause it would be rude (impossible) not to.
    John
    May 2012
    whitehaven
    26
    Your absolutely right but I don't need to use a high powered motorbike engine. The problem with the suspension is that I want to keep the cars identity
    Rods 'n' Sods Junkie mfp-66's Avatar
    Apr 2010
    cumbria
    334
    177
    mfp-66 is offline
    Looks like you could do with a mg midget as a donor vehicle
    13,149
    i understand you need 8 points to keep the identity. so if you had :- 5 points - 'uncut' chassis (compulsory part of the total), 2 points - both front and rear suspension and 2 points - steering, that's 9 in total. then you can change the engine/box and front and rear axles giving more power, stronger axles and better brakes. you could just add better brakes to the stock front axle to simplify that end. whatever you do, good luck with it.
    Nov 2009
    Petworth West Sussex
    362
    59
    streetwise is offline
    Here's my project, been on hold for a while. It uses an amalgamation of different Austin 7 parts, with a "tweeked" reliant engine and box. It drops straight in! Have fitted morris minor hydrolic brakes/drums and lever arm shocks on the back with mini shocks on the front, Hope that helps with your thoughts
    Cheers Dave
    1. austin ruby body
      By movinghotods in forum Stuff - FOR SALE
      Last Post: 16-06-2010, 18:50
    2. Rod Body, A, 32,34, Pop, Y, Ruby, Seven ?
      By WB54 in forum Stuff - WANTED
      Last Post: 29-03-2010, 19:40
    3. Austin 7 Ruby wanted cash waiting
      By hotrodney69 in forum Vehicles - WANTED
      Last Post: 01-02-2010, 18:30
    4. pinto / ruby
      Last Post: 10-08-2009, 15:52
