scott's mk2 zephyr
Results 1 to 10 of 15
    13,137
    mygasser is online now
    scott's mk2 zephyr
    scott decided that very low wasn't low enough for his zephyr so we're making it stupid low. we've fitted an escort axle with adjustable diagonal 4 link bars. and mountad 2 1/4" springs on new perches behind the axle. the boot floor had to have a 'hump' for diff clearance and the prop flange pointed straight at the floor under the back seat so a new tunnel is to be made. the bracketry is above the scrub line before you ask. we're also fitting a 4 speed and o/d box to the mk3 zodiac motor in it so it'll cruise better on the motorway. that with the 3.54 ratio diff and 15" wheels it should scoot along nicely. we got this far in an afternoon and 1 evening after work including stripping the original axle and suspension.
    Rods 'n' Sods Junkie racer132's Avatar
    Mar 2011
    Deal, Kent.
    182
    racer132 is offline
    Bloody hell you lads work fast !
    Official RnS Addict ROCKIN WOLEY's Avatar
    Eating JAFFA'S In The Workshop
    3,624
    1953
    ROCKIN WOLEY is offline
    Lookin forward to seeing this on the floor.
    Jeff
    Injection is nice but I'd rather be Blown
    CHARNWOOD CRUISERS
    nowhere
    7,030
    2406
    nobody is offline
    how do you stop the spring from coming out.
    do you fit some sort of limiter strap
    looking forward to seeiing how low it will sit
    13,137
    the shock is fully extended before the spring dislocates, just like a cortina used to be (although they had springs on the lower arm the principle's the same). when the fender skirts are in place you can only see the tyre on the rear, none of the wheel is visible. the front has to come down another inch and half ish so it will be a car to avoid speed bumps in (careful route planning ahead).
    Official RnS Addict Flamed Cortina's Avatar
    Apr 2010
    Bugle Cornwall, U.K
    816
    194
    6
    Flamed Cortina is offline
    Liking the look of this, whats the idea of the Escort axle?
    13,137
    it's cheap, available and has a better ratio (stock is 4.44:1!).
    13,137
    today we fitted the new gearbox crossmember. tube type as seen on rods with a polybush mount. also started to mount the hurst competition plus shifter to the side of the box.
    13,137
    we got the shifter brackets, propshaft and new rear tunnel made last night. also scott's mate terry came up and recovered the seats and made and covered new door cards for him. after all scott roadstered his minor a few weeks back so it was only fair.
    13,137
    the axle's out for final welding and paint. the 4 link's painted. also the chassis is plated with 2mm plate inside, out and underneath as well as a 2" 'c' notch for more travel. we welded bump stop brackets inside the rails for a real feeling of luxury last job before the underside's shutzed is to weld in the upper shock pockets we've made, these let the top of the shock go up inside the car so they don't bottom with the new 'c' notches.
    1. Granada autoboxes x2,Mk2 Zephyr spares.
      By Greezygringo in forum Stuff - FOR SALE
      Last Post: 21-08-2013, 21:45
    2. Mk2 zephyr 383 / 727
      By gez toxi-coco in forum The Garage
      Last Post: 19-01-2010, 14:31
    3. If you had my mk2 zephyr....
      By Coppertop in forum On Topic
      Last Post: 02-09-2009, 13:57
    4. Mk2 Zephyr Speedo cable?
      By Coppertop in forum Tech Discussion
      Last Post: 17-08-2009, 19:03
    5. Mk2 zephyr fibre glass boot lid
      By ZEPHYRV8CHRIS in forum Stuff - FOR SALE
      Last Post: 27-07-2009, 09:15
