spliffy the panel - Page 5
Likes Likes:  5
Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 51
  1. #41
    Sep 2019
    Nr Malvern, Worcs
    118
    budetta is offline
    Well all flatted and painted on Sat, one dry coat on body . Today had to flat back some due to dust , must have blown up from masking even though I went over it with blow gun first. Wet floor and double tack raged and its come out ok with 3 coats , sag on front panel . Stood to close as not enough room , ended up using my "small" gun as the borrowed "big" gun put out narrow spay compared with my 3,000 year old top feed AID . It does do a good 6ins spray.
    Still not painted outside of sliding door as not enough room , will sheet up bus first as do have proper masking plastic sheet. Take some pics tomorrow , it was put paint on and leg it as to much fumes (no extractor)
  3. #42
    Sep 2019
    Nr Malvern, Worcs
    118
    budetta is offline
    Result of my labours .Needs a flat and polish, good job I can borrow a mop.
  4. Likesdrseg liked this post
  5. #43
    Sep 2019
    Nr Malvern, Worcs
    118
    budetta is offline
    Finished paint , did inside of tailgate, side door and shuts in white. Started fitting bits back on, spent ages cleaning paint of parts . That's from the repaint when it was given the "cal look " back in the 90s? . Hope to fit side door tomorrow, now that will be fun getting it adjusted . Need to order things like cable seals, grommets as stuff rotted/missing .
  6. Remove Advertisements
  7. #44
    Sep 2019
    Nr Malvern, Worcs
    118
    budetta is offline
    Side door fitted, took ages cleaning paint from bolts and out of crossheads!! Nothing was masked or removed for that £50 respray. started to mop, found I need to flat out some more--------
  8. Likesdrseg liked this post
  9. #45
    Sep 2019
    Nr Malvern, Worcs
    118
    budetta is offline
    Spent all day yesterday wet flatting and mopping , nearly go one side done. Started getting cramp in my hand!! Its not mirror finish but don't want it perfect as want it to look a bit "used" and not fresh . TBH don't think they were ever that good new, the new (Brazilian ) panel has ripples from inner frame spot welds and that's factory . Anyways have another day of flatting and mopping today , apart from one bit I think the other side is better finish .
  10. #46
    Jun 2011
    bradford west yorkshire
    420
    481
    splitty66 is offline
    Looking good ,nice colour.
  11. #47
    Sep 2019
    Nr Malvern, Worcs
    118
    budetta is offline
    Getting there, its Velvet Green that's a carry over from split bus.
  12. #48
    Sep 2019
    Nr Malvern, Worcs
    118
    budetta is offline
    Started fitting up doors, taking bloody ages with cleaning over spray of every thing and making stuff fit correctly . Now find the pattern door handles (push button one year only) don't move far enough to work release on latch by 2 to 3 mm . Will have to fit a spacer washer under the finger part that works locking mech . Lots of swear words (insert your own) pattern crap.
  13. #49
    Official RnS Addict heavychevy's Avatar
    Jun 2009
    Sweet Home Northampton
    1,357
    74
    heavychevy is offline
    Keep up the good work!
  14. #50
    13,143
    Quote Originally Posted by budetta View Post
    that 2-3mm saves them 0.05 pence on each one they make, it's all about profit.
