Steel model a king cab pick up - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    Rods 'n' Sods Junkie bluedan68's Avatar
    Jun 2009
    exeter devon
    487
    257
    bluedan68 is offline
    done a load more welding and boxing of the frame, just takes so long having to stitch it then let it cool so it does put too much heat in the steel work! couldn't finish boxing because i'm not sure about a steering box so we lifted the engine and box back in and the body back on so we could tackle the gearbox crossmember and peddle box.
    So i tried the peddle box for size and seams to fit quite well, it's a tci prebuilt item running a hydraulic clutch aswel. I'm not going to be running a servo as it's drums all round. Then tried to build a gearbox crossmember this was my first attempt!!
    I'm here coz it's a cool place to be
  3. #22
    Jun 2009
    exeter devon
    487
    257
    Decided after a bit of thought i didn't like that so came up with this, i'm probly going to split it so i can remove the centre but it's in there for now
  4. #23
    Jun 2009
    romford essex
    3,008
    1170
    296moon is offline
    Likeing the build dan, looks like you have a tube bender there could you not do a large X in tube simlar to stock chassis with a short removeable centre mount, ok junk that forgot the kicked up front rails!
  6. #24
    Jun 2009
    exeter devon
    487
    257
    Quote Originally Posted by 296moon View Post
    mark, i was having great problems trying to make the crossmemberi couldn't go any further forward on the pasengers side as i'm next to the kick up and the peddle box and gearlinkage is in the way on the drivers side so thats how we ended up. I think i'm going to have another x member just behind the gearbox mount made of the same tube to help make it more rigid.
    cheers dan
  7. #25
    Jun 2009
    exeter devon
    487
    257
    now the basic chassis is done and i've got engine and box in place i thought i would do a bit of body work. I cut one of the b-pillars down the centre top to bottom (remember this was a four door)
    once i had two pillars as such (one for each side) i cleaned up the c-pillar area and cut off the edge back so i could slide this in behind and clamp it in place
    made sure the door fitted of sorts and decided to tack it in place and make a cardboard template for the big whole i had at the bottom(was rear wheel recess) before transfering that to the rear door, i did make it 10mm bigger all the way round so i could a recessed edge that would slip behind the panel and give it more strengh.
  8. #26
    Southampton/England
    79
    10
    Doug Jones is offline
    Hey Dan,
    That's looking good.
    I often wondered if the body got used. It's good to see you're building
    it in the style you described when you collected it.
    Keep going with it & updating this thread.
    'Mark Bulls mate'.
  9. #27
    Jun 2009
    exeter devon
    487
    257
    Quote Originally Posted by Doug Jones View Post
    Hey Dan,
    'Mark Bulls mate'.
    Yes i said i'd build it when i got time i just didn't relise a few years would pass first!! i've had the idea for about 5 years and a few small details have change and a few things adapted but it's still the same basic idea.
    Anyway on to more welding i've plated in the kick up at the rear, then tacked a couple bits of box in and the axle to that to get it off the jig. Wanted to get it outside and give me a better idea of how it looks.
    so we have an idea of how it's looking now, obviously the grille isn't in the right place but i'm pleased with the look.
  10. #28
    Rest in Peace
    Earl Shilton
    4,385
    1117
    SG57 is offline
    I'm enjoying this thread, some great work and ideas. Looking good!
    Rog.
    If some's good, more's better and too much is just enough
  11. #29
    Numpty kennyrodgers's Avatar
    Aug 2010
    Preston,Lancs
    477
    78
    kennyrodgers is offline
    Any updates for us on this one bud ??
  12. #30
    Aug 2010
    Preston,Lancs
    477
    78
    Hi bud,
    I tried to pm you but your inbox is full.
    Could do with a bit of advice please, I'll try again soon.
    Pete.
    1. 1928 Ford Model A Closed Cab Pickup
      By 441metisse in forum Vehicles - FOR SALE
      Last Post: 06-08-2010, 09:21
    2. 1926 Essex (All Steel model late 1926)
      By juliebuffy in forum Vehicles - FOR SALE
      Last Post: 03-05-2010, 09:50
    3. 28/29 closed cab pick up
      By jack earls in forum Vehicles - FOR SALE
      Last Post: 28-04-2010, 09:18
    4. Model A closed cab pickup bodies
      By Rich G in forum Tech Discussion
      Last Post: 16-12-2009, 07:45
    5. Steel 32 Model B truck cab
      By Deuces Wild in forum Stuff - FOR SALE
      Last Post: 07-10-2009, 08:29
