Taxi-based Pick up - Page 39
Likes Likes:  19
Page 39 of 90 FirstFirst ... 29 37 38 39 40 41 49 89 ... LastLast
Results 381 to 390 of 900
  1. #381
    23,045
    Roller the primer on, it's the way most bodyshop work on small repairs down here as it saves time getting it in the oven etc. I've done it on many cars now, easy to build up on areas where it may be a bit ripply as well.
  3. #382
    Dec 2010
    Near Canning Town, London
    1,658
    1750
    Taxirod is offline
    What size tip are you using for primer?
    1.8 or2.0 is the right size. If you are using a finishing gun - 1.4 or 1.6 tip you will never get the primer to spray properly without over thinning it.
    Drat! I just bought a new gun, they said I should have 1.4, so thats what i bought. Thanks for the advice. I did manage to get a good few coats of primer on today with the new compressor.
    I have enjoyed this build all the way through all the stages, but I HATE this bodywork bit!
  4. #383
    Dec 2010
    1,658
    1750
    Taxirod is offline
    How do I do that? Do I mix the primer and hardener together, then put it in a tray like painting the ceiling in my house then?
  6. #384
    8,717
    1754
    blackpopracing is offline
    Yep, use wickes 4" gloss rollers and throw away after use.
    You can get different tips/needles for your gun to convert it easily enough.
  7. #385
    Dec 2010
    1,658
    1750
    Taxirod is offline
    Thanks Blackpopracing and Kapri for the advice. Today I picked up paint rollers, snatched an hour or so in garage to do another round of filling/sanding, then went to roller some primer on and....
    Run out of hardener!
    Progress feels so slow sometimes! But I keep telling myself that it is going forward.
  8. #386
    Feb 2013
    uranus
    2,104
    ivanhoew is offline
    it definately is ian, if you look back through the thread you can see that you have made amazing progress with the minimum of kit , and expense. NICE JOB.
  9. #387
    Dec 2010
    1,658
    1750
    Taxirod is offline
    Thank you, I needed the encouragement.
    Ive been putting on primer with a roller, good way of getting plenty on without spraying, thanks Kev and Blackpopracing.
    keep noticing more and more details that need sorting out. I guess thats just the prep process.
    no point posting pics at the moment, after a hard days work the pic would not look much different!
  10. #388
    Dec 2010
    1,658
    1750
    Taxirod is offline
    Been working away to get the bodywork as good as I can, door gaps far from perfect but better than a lot of the taxis as they came from factory...
    guide coats...
    ...and finally, PURPLE!!! even if its just the door shuts and inside bits.
    I like the look of the trans tunnel, might leave it exposed in final interior. Although I think it may transmit too much heat to the inside of the truck. I can always add insulation and carpet later I suppose.
    I'm pleased with the paint colour, just the skill of the sprayer which leaves a lot to be desired.
    Hoping to paint outer body tomorrow.
  11. #389
    I'm a newbie !
    Dec 2012
    folkestone
    spud87 is offline
    love reading all these thread u do, looking sweet mate
  12. #390
    12,747
    you can always add dynamat or similar underneath the tunnel ian
There are currently 3 users browsing this thread. (0 members and 3 guests)
    1. roadster and pick up
      By jonesy in forum The Garage
      Last Post: 10-10-2010, 08:26
    2. The Big Yella Taxi
      By bigyellataxi in forum The Garage
      Last Post: 17-08-2010, 19:24
    3. 29 A pick up
      By kapri in forum The Garage
      Last Post: 27-05-2009, 09:35
    4. Replies: 2
      Last Post: 07-05-2009, 19:22
    5. Du Pont solvent based paint - help
      Last Post: 06-05-2009, 08:00
