Taxi-based Pick up - Page 87
Likes Likes:  11
Page 87 of 89 FirstFirst ... 37 77 85 86 87 88 89 LastLast
Results 861 to 870 of 887
  1. #861
    Dec 2010
    Near Canning Town, London
    1,622
    1711
    Taxirod is offline
    might consider popping a wide band lambda gauge on the dash Ian , so you can see the air fuel ratio as you drive and see if its leaning out ..the aem ones seems good .
    .....Er, I already got one.......!
    (check out post 857 above, AFR gauge has black rim just above steering column)
    I couldn't understand why she was rich on cruising, lean on acceleration, and didn't respond to my attempts to change that the other way round.....
    So I sold the Holley and bought a pair of Edelbrock blower carbs...... same problem!
    Now Ive sussed it the engine is scrap!
    All part of the fun.
    Challenge now is to get her up and running again asap without spending too much money.
    If someone has a 350 SBC with forged pistons which they want to give away.......
    .....Oh well, perhaps not.
    So I'm probably gonna fit a 305 for now.
  3. #862
    Feb 2013
    uranus
    2,053
    ivanhoew is offline
    ooops
    Bicester scramble ,Medusa enjoyed the trip.https://www.youtube.com/watch?v=Q-7I7-nA19U
  4. #863
    Dec 2010
    1,622
    1711
    Taxirod is offline
    So brought the 305 SBC home, only place I could put it in the dry was the engine bay.
    I havent dropped it right in yet, want to check starter shims etc while you can actually poke the paper clip in.
    A list of stuff to sort before she's up and running:
    Drill inlet manifold to suit vortec heads.
    Swap camshaft for the blower cam from previous engine.
    Sort out how to mount blower pulley and v drive onto harmonic balancer.
    Also I will probably scrap the 2nd radiator mounted at the rear, and make a shroud for the front rad and switch from mechanical fan to electric.
    I will also need new rocker covers to suit the centre bolt heads - anyone got some that I could buy?
  5. Likessteve1275 liked this post
  6. Remove Advertisements
  7. #864
    Feb 2013
    uranus
    2,053
    ivanhoew is offline
    ooooh excitement .. i wonder what the new boost level will be .
  8. #865
    12,566
    ian, you can get adapters to fit your early valve covers to centre bolt heads mate.
  9. #866
    Dec 2010
    1,622
    1711
    Taxirod is offline
    As the 305 has stock pistons I'm going to keep it down to about 6 or 7 psi, should be fine ..... if I set the fuel pressure correctly!!!
  10. #867
    Dec 2010
    1,622
    1711
    Taxirod is offline
    Thanks Neil.
    That's another possibility, I see what comes up.
    I might end up using my old heads anyway.
  11. #868
    Feb 2013
    uranus
    2,053
    ivanhoew is offline
    Quote Originally Posted by Taxirod View Post
    i was thinking if you had he same pulleys as before ?
  12. #869
    Aug 2015
    haarlem the netherlands
    316
    watahyahknow is offline
    from wat i heared the vortec heads flowed better , not sure if the 305 heads where like that too
  13. #870
    Dec 2010
    1,622
    1711
    Taxirod is offline
    Yes, same pulleys, I'll see what boost i get, can swap them around or get different sizes if necessary
    1. roadster and pick up
      By jonesy in forum The Garage
      Last Post: 10-10-2010, 08:26
    2. The Big Yella Taxi
      By bigyellataxi in forum The Garage
      Last Post: 17-08-2010, 19:24
    3. 29 A pick up
      By kapri in forum The Garage
      Last Post: 27-05-2009, 09:35
    4. Replies: 2
      Last Post: 07-05-2009, 19:22
    5. Du Pont solvent based paint - help
      Last Post: 06-05-2009, 08:00
