Tribute to Edwardian aero engined cars and Land Speed Record cars of the 1920's - Page 23
Likes Likes:  5
Page 23 of 25 FirstFirst ... 13 21 22 23 24 25 LastLast
Results 221 to 230 of 243
  1. #221
    13,783
    it looks like the bottom of the column now may be in the area of the pedals which may cause issues with them. if you did what i suggested and just angled the mount where the column bolts to the 'framework' the wheel would be lower but the column at the pedal area would be in the same place.
    bolt it back up with the thin bit of wood but leave the bolts loose which will allow the weight of the wheel to lower/angle the column and wheel to where you need it.
    this also makes the wheel more vertical like a vintage car. once the position is correct make an angled bracket to hold it there. it's not rocket science. all you've done is space the whole thing down but not changed the angle at all.
  3. #222
    Jul 2015
    Notts
    327
    271
    stormbird is online now
    Neil
    Thanks for your input , I am listening and still fiddling
    The picture does show it being tight however there is clearance and the pedals are well below the visible bit of the column.
    On my list to try.
    Need to try more vertical , if there is clearance for my knee's
    all you've done is space the whole thing down but not changed the angle at all. neil.
    yes I have not changed the angle , I am not sure the angle was wrong ?
    The plate wood mount moved the column both up and back.
    The new wood mount now only moves the column back , which is a big improvement.
    all a learning curve for me , but enjoying most of it never the less Paul
  4. #223
    Feb 2013
    uranus
    2,450
    ivanhoew is offline
    in case it helps paul,
    regards
    robert
  6. #224
    Jul 2015
    Notts
    327
    271
    Robert
    Still trawling your thread for how to do things and idea's.
    been looking at your the torch/bulkhead/radiator idea , sadly my garage is short and the drive slopes so steeply I think the torch would have to be halfway down the drive and @ 10ft height !
    Always amazes me you found room in Medusa for your feet
    Paul
  7. #225
    13,783
    the point about changing the angle of the column is it will make the wheel more vertical without putting it any closer to your knees. think of it like this, the column angle pivots at the mount which swings the wheel in an arc. the lower (more horizontal) the column is (at the wheel) the more vertical the wheel becomes.
  8. #226
    Feb 2013
    uranus
    2,450
    ivanhoew is offline
    Quote Originally Posted by stormbird View Post
    Robert
    Paul
    well i do have to wear my special "M.B.S." (medusa ballet shoes)
  9. #227
    Jul 2015
    Notts
    327
    271
    without putting it any closer to your knees. neil.
    That is the bit that puzzles me ?
    No time today to play , honey do list day ...
    maybe tomorrow Paul
  10. #228
    Feb 2013
    uranus
    2,450
    ivanhoew is offline
    the pivot point has to travel upwards as well paul.
  11. #229
    Jul 2010
    garden of England
    608
    27
    thisYup is offline
    as you seem to be getting in a bit of a twist, put the steering wheel where you want it, ignore any routing so far and then join the dots to the steering box....
  12. #230
    13,783
    maybe tomorrow Paul
    no closer to your knees than with the 4" block of wood your last mockup showed. if the wheel is where you want it with that 4" mockup all you need to do is raise the bracket end (but not the wheel) back up and replace the block of wood with a thin angled bracket. without lifting the wheel it is now more vertical. tadaaaa!
There are currently 7 users browsing this thread. (0 members and 7 guests)
  1. Replies: 0
    Last Post: 19-04-2014, 07:16
  2. Replies: 7
    Last Post: 29-04-2012, 14:31
    Last Post: 20-10-2011, 22:11
    Last Post: 09-09-2011, 16:26
  5. Replies: 0
    Last Post: 03-02-2011, 12:04
