Tribute to Edwardian aero engined cars and Land Speed Record cars of the 1920's - Page 27
Likes Likes:  7
Page 27 of 27 FirstFirst ... 17 25 26 27
Results 261 to 263 of 263
  1. #261
    Jul 2015
    Notts
    353
    290
    stormbird is offline
    Quote Originally Posted by thisYup View Post
    Can't you move the runners in, 1/4-1/2 inch or will the seat not allow? If not move the runners in 1/4-1/2 inch and move the seat mount on them out the corresponding amount.....��
    By jove that's a good idea ?
    maybe been to blinkered by being tied in to what I have done so far , will get the tape measure out and see how much would help.
    Just moving the one runner in by about 2" could do it ?
    How narrow could the gap between the runner be and still work ?
  3. #262
    Jul 2015
    Notts
    353
    290
    Ok thought time I did something ?
    Need a battery tray ? so knock one up ...
    Oh so traditional bit of angle iron and a couple of stretchers
    Wondered whether I could mount it say 2/3 in engine bay and 1/3 in passenger foot well ?
    With access from the engine side ?
    Looks workable and the passenger seat is so far back that I doubt the feet will come past the box section on the floor just inside the dashboard line ?
    So box it in on the passenger side and add a cross beam a couple inches above the battery for strength.
    The passenger needs a foot rest and the battery tray can be braced of the pad on the chassis and the tube alongside the gearbox on the engine side , maybe a couple of short angled braces underneath on the passenger side so all braces are in compression sounds about right.
    Paul
  4. #263
    Jul 2015
    Notts
    353
    290
    Hi all
    Bit the bullet and bought a heater , rear heater from a taxi apparently ? had what I wanted just 2 pipes in and 2 speed fan.
    So this was inside [ the motor is in the other part of the casing ] :-
    Looks like a good vacuum clean out and it should be OK.
    Imagine the piece of wood is a new vertical in the firewall so the pipes will end up on the engine side and the mesh air out will be in the foot-well both pointing to the inside of the car
    In this picture the rad goes behind the grill and the cross piece that says Engine side will be cut out and the heater sat further inside the bonnet bolted to the lower shorter horizontal.
    Another cross piece will replace it but now above the heater across the the vertical in the centre and the battery tray will sit on that also partially inside the cockpit.
    This is the cockpit side but the heater will be far enough inside the engine bay to allow the water pipes to be plumbed in.
    I need to blank off the mesh on the fan side with some sort of outlet in the blanking piece to divert the hot air into the foot-wells with maybe a manual control to divert it all to the driver if there is no passenger.
    I wanted to use some steel stove chimney pipe for that but it seems very expensive [ from MachineMart ] although it maybe twin walled [ only only need single ] it may have to be plastic guttering down pipe and elbows ?
    all for now Paul
  1. Replies: 0
    Last Post: 19-04-2014, 08:16
  2. Replies: 7
    Last Post: 29-04-2012, 15:31
    Last Post: 20-10-2011, 23:11
    Last Post: 09-09-2011, 17:26
  5. Replies: 0
    Last Post: 03-02-2011, 13:04
