Wooden Buck Hot Rod - Page 2
Likes Likes:  54
Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 100
  1. #11
    Jul 2014
    New Zealand
    248
    5
    mylesdw is offline
    Surely the random choice of parts does not matter too much for BIVA, more a question of whether you end up with a Q plate or not.
  3. #12
    I'm a grown up member now ! seventhheaven's Avatar
    Sep 2012
    Dorset
    43
    96
    seventhheaven is offline
    Quote Originally Posted by mylesdw View Post
    I sooooooooo need to read Kev's guide. Anyone reading this should do the right thing (It's xmas), place a donation and get themselves a guide. Hats off to you Kev!
    I'm waiting for the thud on the doormat, then my morning reads are sorted!
    Ask me to fix something and I'll come at ya with a hammer!
  4. #13
    Sep 2012
    Dorset
    43
    96
    It took a little longer than expected, but I've almost finished my English Wheel.
    It's got a 38" throat, stands 8 foot tall and weighs nearly 26 stone.
    It still needs a few bits adding and a new adjustment wheel but basically it's there.
    I was worried about flex, but it seems pretty solid.
    Now all I have to do is learn how to use it.
    I'm going to get a bit of practice in, then maybe do a course at mph
    http://www.super7thheaven.co.uk/blog/diy-english-wheel/
  5. LikesTorment, mygasser liked this post
  6. Remove Advertisements
  7. #14
    Official RnS Addict ChopperHarris's Avatar
    Oct 2011
    SW France
    1,319
    21
    ChopperHarris is offline
  8. Likesscottie liked this post
  9. #15
    nowhere
    7,089
    2412
    nobody is offline
    Looking forward to this progress. Have you done work on an english wheel befor
  10. #16
    Herts
    4,617
    224
    WB54 is offline
    looks like a great project, it looks quite like a Fiat Topolino.
  11. #17
    Rods 'n' Sods Junkie Austin Martin's Avatar
    Sep 2011
    Essex
    474
    36
    Austin Martin is offline
    That wheeling machine looks a great piece of kit, even if the car doesn't work out, you can be proud of that at least!
    Just a passer by as you might say.
  12. #18
    Jun 2009
    romford essex
    3,020
    1185
    296moon is online now
    Quote Originally Posted by ChopperHarris View Post
    Not seen that, thanks
  13. #19
    Sep 2012
    Dorset
    43
    96
    I've got all the Lazze videos playing on loop in the workshop. I've even got most of the Ron Covell videos.
    Getting the back and forth wheeling action didn't come naturally. My Zig Zagging is getting better, even though I still need to tighten the 'Z' a little.
    I seem to be concentrating more on my Zig Zag than the workpiece. I haven't got the fluid action of Lazze/Ron, I keep having to have a little think as to which way to turn the metal.
    I'm also not great at stopping in an even line. It's going to take some practice that's for sure
    I made my first teardrop
    I might lower it slightly as it's killing an old shoulder injury. Lazze and Ron make it look so easy, but with a rippled piece it takes some heaving back and forth. Even at twice my bodyweight I can drag the wheel around.
    Starting with flat steel or once a buckled piece is semi-smooth it's much easier - I'll see how I go.
    I think next time I'm making mirrored pair, I'll make all the individual bits at the same time and cleco them together. As one side grows the other will too.
    That way I'll be able to adjust things easier to get them to match. Each sill and pillar are actually made of 8 bits of steel. That's too many to weld in on go.
    I'm still learning - making plenty of mistakes actually helps somehow.
    I've done the second sill and door pillar, which means I can mount the hinges. They give me the datums for both sides.
    This sill is curved so I couldn't do it in the brake, so I did it in the bead roller with a tipping die. With each bend I then shrunk or stretch the metal to get everything straight again.
    That meant I was often stretching metal I'd just shrunk.
    I think I need to get my Gas welding skills up, as without a wheel I'd end up with a buckled mess. A flat anvil in the English wheel has proved invaluable.
    read more:
    Hand built Bodywork - Drivers Side Door Pillar - Super 7th Heaven
  14. Likes296moon, grizz, steve1275 liked this post
  15. #20
    Sep 2012
    Dorset
    43
    96
    With the 2 door pillars done, I started the bulkhead.
    I made a brace to join the two pillars and keep them square. It also gave me something flat to put a spirit level on.
    For the front, I didn't want a total flat piece of steel so I added some bead rolling.
    I had to butt weld it done the center so that it would fit the roller.
    The next bit is going to be the hard bit as the MG Midget screen has a double curvature to the bottom edge.
    It's 2.75" higher in the middle and also 2" further forward than the edges.
    This time, I've cleco'd everything in place so I can adjust things latter if necessary.
    read more here:
    Hand Made Bulkhead - Super 7th Heaven
    1. Wheels , tyres, sbc inlet , carb, bed ( buck ) cover
      By voodoom in forum Stuff - FOR SALE
      Last Post: 23-03-2013, 22:04
    2. Big Buck Motor !!!
      By Zody in forum On Topic
      Last Post: 01-02-2011, 20:23
    3. Uncle Buck
      By 55chev in forum Chat
      Last Post: 25-12-2010, 13:00
    4. wooden garages
      By chubbs in forum National Street Car Challenge (NSCC)
      Last Post: 12-12-2010, 09:34
    5. Insulating a wooden garage
      By beach57 in forum On Topic
      Last Post: 10-12-2010, 20:18
