Wooden Buck Hot Rod - Page 5
Likes Likes:  54
Page 5 of 10 FirstFirst ... 3 4 5 6 7 ... LastLast
Results 41 to 50 of 100
  1. #41
    Stroker Kustom Jim's Avatar
    Bath
    5,216
    2764
    Kustom Jim is offline
    Thumbs up
    funny as ****
    Yeah, can't help keep laughing
    Amazing build mind! Hot Rodding at its finest
    It must be totally absorbing, designing, creating, learning skills and taking a step back to say "yeah baby, I did that!"
  3. #42
    I'm a grown up member now ! seventhheaven's Avatar
    Sep 2012
    Dorset
    43
    96
    seventhheaven is offline
    I've not done much recently, due to health and time, but I've started to create the profile for the bonnet.
    You can just about see the 5mm bars I'm using to guess the profile.
    They are just Duct taped in place. If you can't fix it with Duct Tape - You ain't using enough Duct Tape!
    I bent them around my buck, but unfortunately that's been under a hole in the roof and has swelled up and split.
    It's 2.5" taller at the back than at the front.
    I think I'll make the bonnet a little more shallow at the front, a bit like this '37 lookalike.
    I think I'll change the slope from 1.5 degs to closer to 3.
    I've finished the second air cleaner and started the front support for the horizontal grille bars.
    They might only be £6 Chinese filters, but boy do they go up in flames fast when you put an Oxy torch near them!
    It's still far from anywhere near complete, but slowly slowly....
    I think once I have these panels complete, I'll throw some mud and paint at them.
    A. to stop them rusting
    B. Because some panels, seem pretty straight, yet look like they've been given a blooming good kicking in photos.
    There's more here:
    More work on the Grille - Super 7th Heaven
    Grille and Slam Panel - Super 7th Heaven
    I know I'll never be allowed to drive this car, but it's hard not to keep an eye on the BIVA spec. Therefore, I've 'blunted' a couple edges 'just in case'.
    I'm not going to be doing any panels that will be particularly visible on the completed car for quite some time - I'm only doing the structure and framework but I don't want to be doing too many jobs twice.
    Ask me to fix something and I'll come at ya with a hammer!
  4. Likes46beddy liked this post
  5. #43
    May 2012
    In the boonies near Hereford
    385
    32
    Moosevan is offline
    Really impressive. Thanks for sharing.
  6. Remove Advertisements
  7. #44
    Sep 2012
    Dorset
    43
    96
    Quote Originally Posted by chaley View Post
    I’m not sure, but I thought gen 1’s lights where VW beetle anyway??
    Chaley
    You were right! Just seen a Beetle lighted version - That thing's way more cross eyed than the one I saw last week!
    I've measured up my scrap Mini bonnet and No they don't quite sit in line (as expected) they actually point outwards?!? WTF!
    I recon Morgan fit LHD units swapped side to side - either that or I've got to be really careful with my wing sculpting!
    I suspect there's some real mind trickery going on here!
    The wrong shaped wing behind these headlamps could make this car look like it's been slapped with the ugly stick!
    My wing shape is going to be Morgan'esque and my wooden buck was made without measurements.
    "Oh look there's that crossed eye Hot Rod again!" - "Tommy, he's looking at me! Looking at me!"
  8. LikesKing Herald liked this post
  9. #45
    Sep 2012
    Dorset
    43
    96
    One step forward, 10 steps back.
    Since I've decided to change my bonnet profile, my wooden buck is now useless.
    I therefore started the internal framework for the bonnet with no reference.
    Of all the things to make endless mistakes on, I had to pick the one that took ages at each step.
    I made the bonnet braces, only to realise the profile needs to be tapered front to back.
    The front of the brace sticks out - that was until I realised I could angle the brace to the bonnet side - doh!
    I then made four identical braces, only to realise the front two were completely useless.
    The profile of the front two is going to be nothing like the rear ones. The bonnet is essentially cone shaped, so the front two will be a scaled version of the rears.
    My initial plan was to cut the bottom off the curves. However that would leave a sharp angle where the bonnet flowed into the sides.
    Also, it didn't dawn on me that the braces I'd made would make a staircase shaped bonnet. I needed to lean them forward to allow a smooth bonnet top.
    I was hoping to have an opening internal framework by now - dream on!
    Oh well...... back to the drawing board.
    Maybe a holiday will give me the motivation I need.
    Bespoke Bonnet - Super 7th Heaven
  10. #46
    Jul 2010
    garden of England
    572
    27
    thisYup is online now
    A rhd light will still be a rhd light regardless of the side it's bolted to, the dipped beam kickup will still be on the nearside... So swapping lights side to side shouldn't be an issue...... Depending on the amount of beam adjustment inside the housings you could mount them angled or square as long as the beam goes in the right direction.... ��
  11. #47
    Official RnS Addict markyb37's Avatar
    Oct 2011
    christchurch , dorset
    619
    1178
    markyb37 is offline
    Hi Mark, great job so far . Just trying to save you a lot of frustration but IMHO you would be better of making your bonnet skin first {as this is the visual part .( It would be a shame to skin a lovely inner frame ,to find the bonnet profile isn't how you would like it ).If your happy to keep going on the inner frame then I have a profile gauge that might be long enough to run front to back .Let me know if this would help. Or another thought , make an external buck for one side of the bonnet then duplicate your frame for the other side ???. its a VERY frustrating job but the bonnet is the main focal point IMHO. Keep up the great work. Mark.
  12. Likesblackpopracing liked this post
  13. #48
    Sep 2012
    Dorset
    43
    96
    Hi Mark, that the difference between years of experience and skill and blundering incompetence.
    My last weekends work was a perfect example of blundering incompetence. The morning was spent standing and staring thinking how the blooming eck do I do this, followed by several hours of repeated failure.
    My mind has trouble picturing shapes in 3D, hence me resorting to the braces.
    I could bend a big sheet of tin, but chances are that's going to be a big waste of a sheet of tin.
    The plan was to create a metal 'brace' equivalent of a wireframe (for the whole car in fact). I was going to create several more braces.
    The front to back profile is OK, apart from the nose cone it's flat. So angle iron is fine as a profile gauge.
    The sideways curve is sort of set by the MG Midget screen. I cut a profile gauge for that - my Midget screen is wonky and far from symmetrical - good ole '70's BL!
    I could blend that curve out in a V shape but that confuses me.
    I did think about a reverse buck for the nose, but to make that I'd need to somehow take a mould off my wooden buck. - all confusing stuff.
    Since I made the braces and realised they needed a different profile front to back, I angle'd them on the car in a V. I've now worked out that doesn't 100% work either as the centre is further back than the front and therefore requires a different profile. Therefore, all four aren't scrap, but they currently aren't the right shape.
    Definitely a weekend of blunder!
    After hols I might come over and pester you for some much needed advice! There's only so much I can learn from Youtube!
  14. #49
    Sep 2012
    Dorset
    43
    96
    Slow Month
    It's been a slow month as I got made redundant. Apparently having a seizure in your lunch break is now a sack-able offence.
    Money's a bit tight.
    The first bonnet frame strengthening ribs had all the strength of organised spaghetti. They would have strengthened a already formed bonnet but what I wanted was something I could forcibly wrap a skin around. So I took a different approach.
    I recently walked around a French museum crammed with brass era cars and early planes. The hand craftsmanship was amazing. You could see every hammer blow, every type of tool used and every flaw. To a certain extent, that's what I want.
    I want a look that is a bit retro, a bit Lancaster bomber with a little steam punk thrown in for good measure.
    My internal bonnet frame now has more dimples than a herd of teenagers.
    At last count there were 108 dimples of various dimensions and the count was about to go up by another 20 or so.
    I done a load of sums in a spreadsheet, plotted them on paper templates and then scribed them onto steel. These were then made into the framework you see below.
    There are still a few dimples to be cut in this shot and the sides are still need doing.
    At the rear I wanted something a little stiffer, so I joined the BMW e46 hinges together with a length of 25mm box. The idea is to have a self opening bonnet (once safety latch is released).
    The inner frame weighs just over 3Kgs and currently 1 gas ram opens the bonnet rather too quickly for my liking, so things are looking promising.
    Propped up below, as gas ram currently opens bonnet beyond 90 degrees (need to make a bump stop).
    During the fitment of the above square box section, I realised it was too high and too far forward. The corners poked out through the currently imaginary bonnet skin.
    I had to take the whole bulkhead assembly apart to recess the hinges.
    This involved a lot of swearing as not only did I have a nightmare getting everything to re-align again, I also had to have eye surgery to get shattered cutting disc remove from my eye.
    With the ribs in place, I can now tweak the profile of the bonnet by running a straight edge between predetermined points on the bulkhead and the front brace. If any of the braces are too high I can file them down or if they are too low I can carefully twist the framework to raise them.
    At any given point on a radius I'll have 10 points along the length of the bonnet with solid structural points I can fold the skin around. If I can get the bonnet bent somewhere close, at bit of pressure against the internal framework should hold the bonnet skin 100% in the right place.
    Well, at least that's my theory....... I'm am making this up as I go along......
    read more here
  15. Likesdrseg, steve1275, mylesdw, jono_misfit liked this post
  16. #50
    Sep 2012
    Dorset
    43
    96
    I bought a Morris 1000 roof on fleebay.
    It was an 11 hour round trip (I don't drive) and it needed cutting down the middle to fit in the car but it was too cheap to miss.
    The initial plan was to cut it up as soon as I got home, so I didn't mind cutting it up to get it in the car.
    I didn't expect to use and awful lot of it, but I actually just welded it back together and propped it in place. I could have used it whole.
    It's too peaked in the middle for my liking, but I'll grow to like it.
    The windscreen pillars aren't finished and barely have any strength in them, so they flex a bit at the moment.
    The rear screen is the larger Morris 1000 version. I have a smaller earlier Morris Minor version.
    Eventually, in Lead-sled fashion, I'll lower the rear of the roof slightly by 2 inches and raise the rear window.
    The rear window is also way too vertical. It needs leaning over by another 40 odd degrees.
    It'll go back into storage until I have a solid framework to support it. But the Moggy roof is in theory a viable option
    read more here
  17. Likesmygasser liked this post
    1. Wheels , tyres, sbc inlet , carb, bed ( buck ) cover
      By voodoom in forum Stuff - FOR SALE
      Last Post: 23-03-2013, 22:04
    2. Big Buck Motor !!!
      By Zody in forum On Topic
      Last Post: 01-02-2011, 20:23
    3. Uncle Buck
      By 55chev in forum Chat
      Last Post: 25-12-2010, 13:00
    4. wooden garages
      By chubbs in forum National Street Car Challenge (NSCC)
      Last Post: 12-12-2010, 09:34
    5. Insulating a wooden garage
      By beach57 in forum On Topic
      Last Post: 10-12-2010, 20:18
