Worlds most normal speed rebuild - Page 7
Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 61 to 70 of 72
  1. #61
    Rekindled Dream Chunky's Avatar
    Aug 2009
    Moston, Manchester, UK
    2,064
    70
    Chunky is offline
    Good Man Sid
    Quote Originally Posted by sidspop View Post
    Ash, give me a shout when you want your CB doing, I have quite some experience. Plus it's about time I came and drank your coffee.
    Life's journey is not to arrive at the grave safely in a well preserved body , but rather to skid in sideways, totally worn out, shouting "Holy shit ... what a ride"
  3. #62
    Official RnS Addict lambretta_ash's Avatar
    Aug 2011
    birmingham, quinton/oldbury
    1,196
    287
    lambretta_ash is offline
    Quote Originally Posted by Chunky View Post
    Hi
    What sort of aerial mount have you got as the bigger the metal surface under the aerial the better, which is why we used to see them in the middle of the roof.
    ... Jon
    its mounted on the right rear quarter rubbed down well so good earth but was thinking real 80's and having two whipps
    hows decaff haha not a prob this does look simple to me so might have a go when i finished the exhaust and can roll to a field haha
  4. #63
    Aug 2009
    2,064
    70
    Chunky is offline
    [QUOTE=lambretta_ash;622577]its mounted on the right rear quarter rubbed down well so good earth but was thinking real 80's and having two whipps
    Hopefully that should work OK.
    Re using 2 whips. There is something called impedance for the coax cable on these types of aerials and a single one measures 50 ohms. Ordinary car radio aerial coax cable is different at 75ohms so can't be used.
    If using two whips you'd have to make up or buy an impedance matcher or balun because when you join 2 x 50 ohm coax's in parallel you would get a resulting impedance of 25 ohms which would affect the efficiency of the aerial and the amount of power put out. In addition without the matcher there is a chance you may damage the output transistors as the loading would be wrong. My advice would be to stick with one for now until you've read up a bit more.
    Placing the aerial on the rear quarter will make it slightly directional as well. Sid will probably know this and explain more.
    Let me know how you get on.
    Cheers ... Jon
  6. #64
    Aug 2011
    1,196
    287
    SOOO alot since i posted last you have got a long read ill start with my hilborn scoop had a saucey pan connecting the scoopto the carb so thought id make one
    used sheet metal and cardboard for a base cutout then the rest is magic
    had to make the throttle linkage work as the bigger carb had a ball type thing ?? so i swapped and cut the old one to make it fit and then re plated it to make it look new
  7. #65
    Aug 2011
    1,196
    287
    and because the carb was bigger the linkage was off so the cable holder didnt fit so i bit of simple felting and jobs a gooden
    I THEN GOT BOREDDDDDD waiting for my boss to make me the manifold blocks so one month of asking n getting bored so i took some pictures
  8. #66
    Aug 2011
    1,196
    287
    once i got them i was over the moon and like a child so i cracked on
  9. #67
    Aug 2011
    1,196
    287
    didnt like where the exhaust was before was too low and hidden so i moved it backwards and up as high as i could go by doing a simple cut and add at the front the pic is on the zinc plated side so abit ruff and the other side :O i think it was repair metal as it didnt wanna weld it was like drilling thru spring steal was solid and just bouncing off
  10. #68
    Aug 2011
    1,196
    287
    ITS NOW ALREADY TO START its its DAMN IT, its not im waiting for a coil as the old one is knackered as kerrang said earlier lol so took some pictures
  11. #69
    Official RnS Addict jaydub's Avatar
    Oct 2010
    North Wilts
    2,447
    901
    jaydub is offline
    Still waiting for a coil?
  12. #70
    Lee
    Fat 'n' Loud Lee's Avatar
    Derby
    4,766
    493
    Lee is offline
    Quote Originally Posted by jaydub View Post
    Too late, she's pregnant now.
    1. Worlds most expensive model car
      By chrisjx in forum The Shelf
      Last Post: 07-01-2012, 21:58
    2. The Worlds most dangerouse creature
      By Iggy in forum Chat
      Last Post: 15-12-2011, 19:04
    3. Worlds most beautiful garages!
      By chevy2 in forum On Topic
      Last Post: 10-12-2009, 18:39
