I it possible to Return to historic if sent for a BIVA
Likes Likes:  10
Results 1 to 10 of 33
    Rods 'n' Sods Junkie john123's Avatar
    Jun 2009
    Leigh on Sea , Essex
    444
    435
    john123 is offline
    As title would it be possible to return a car to historic class if the car fell outside the 8 point rule, by replacing enough of the modified components with stock items to bring it back inside the permitted the 8 point rule, or does the car have to go through a biva , and meet the required criteria, thanks for any replies
    23,047
    No one has attempted it so unknown . However , once they have decided your vehicle doesn't meet the criteria the right to registration ( ie the logbook) is removed and made void at the same time as they advise you have to go for BIVA.
    It MAY be possible to re-register it via Reconstructed Classic class but I don't know if that is possible for certain.
    Personally I tend to advise people to build in BIVA spec when you are modifying , even within 8 points . Most of it isn't a problem , is a good safe build spec and 99% doesn't cost more than NOT doing it to BIVA ie just buy the right spec piece when you are modifying first time around.
    Biggest issue is always the requirement for a laminated and correctly marked front screen . Mostly they can be manufacture or export spec may carry correct markings.
    Do the home work first ( if concerned) to avoid the problem
    Grown up? Never!
    Norwich
    2,081
    36
    chaley is online now
    Morning,
    I’ve looked into this myself and as Kev said no one has done it, but…
    At the time of being ‘visited’ it would be easier to convince them to just suspend the V5c and get it done ASAP, as I think once it’s gone it’s gone. If it’s touch and go on the points the inspectors are human and not out to get ‘you’ so worth a try.
    But my advice would be to put it back to 8 point compliant before you get that visit.
    Chaley
    Tetanus
  5. Likeskapri liked this post
  6. Remove Advertisements
  7. #4
    23,047
    I was just about to say the same thing Chaley . There is a process which is preceeded by paperwork , if that starts to happen don't hope for the best, don't start the ball rolling plan for the worse and get it sorted.
    I do know of a ac VW type 3 that had the issue of a chassis notch raised at MOT time and it required further inspection ...by which time it was unlowered and chassis area remade.
  8. #5
    Stroker Kustom Jim's Avatar
    Bath
    4,865
    2638
    Kustom Jim is offline
    Wise words from Kev as usual (you too Chaley lol).
    Interesting question mind and would be great to see an event like that happen.
    Anyhoo, as another one of my asides
    Biva is just an option (maybe appears the toughest but has highest reward!) if log book reg number torn up!?
    Scrap, banger race, race car or as said if poss restore to 8 point!! Let's face it some big resto Jobs have little original uncut metal left etc.
    And as Chaley says and also the most important thing can be to avoid the inspection!! If you're so inclined. Many things can trigger an inspection I understand, back track or say you're in Venezuela for a year and cars at the bottom of a lake!?
    Or head down and channel energy to Biva build
    Unless it's a roof chopped MK1 Lotus Cortina with a restored value of £50 grand
    Carroll Shelby
  9. #6
    Official RnS Addict mattblack's Avatar
    Nov 2013
    A damp lock-up
    596
    78
    mattblack is offline
    Outside of the tester's remit, shirley?
    50 shades of grey primer....
  10. #7
    23,047
    Quote Originally Posted by mattblack View Post
    Not if he felt the work caused danger or weakened the chassis .
    There was a period when testers were advising " Vehicle is highly modified " as well.
  11. #8
    Jun 2009
    444
    435
    john123 is offline
    Thanks for the advice guys , I keep thinking about getting a hot rod and iam drawn to the 50s and 60s builds, so if I do take the plunge one day i will do what you advise , and bring it back into the 8 point rule before getting caught,
  12. #9
    nowhere
    6,619
    2299
    nobody is offline
    Quote Originally Posted by john123 View Post
    Can i ask who youre going to get caught by.
    Biva is up to you to put yourself forward for it. No one is actively looking for you
  13. #10
    Nov 2013
    A damp lock-up
    596
    78
    So it wasn't snagged because it was modified, it was snagged for the same reason it would have been if the chassis rail had been 'repaired' with chicken wire and bondo... that puts a different slant on things.
