Big Block 454 Chevy V8 Engine / Eagle Rotary / Hot Rod / 500BHP+
View Entry Info: Big Block 454 Chevy V8 Engine / Eagle Rotary / Hot Rod / 500BHP+
Category:
Classifieds 1 Item (All details are required to post items in this section.)
Price
Condition of Item
Description
Results 1 to 1 of 1
    I'm a grown up member now ! Kinglee79's Avatar
    May 2013
    Surrey
    43
    Kinglee79 is offline
    454 Big block performance Engine:
    Block number: 14015445
    1987 Gen IV / 2pc Main seal / 4 Bolt Main.
    454 Core Block low mileage 37'000 miles RV Engine.
    Now Fully machined 030 over / Fully deburred & VHT Painted Block /
    Cam Bearings Installed and New Camshaft test fitted.
    Full Eagle Street Performance Rotating Assembly
    Stroke: 4.000
    Disp. @ .030: 460ci
    Rod Length: 6.135
    Pistons: +22cc Dome
    Rings: Standard Gap
    Comp. Ratio 112cc/ 118cc/ 124cc: 10.1/ 9.6/ 9.2
    Eagle I Beam / Hypereutectic Pistons / Eagle Crankshaft / Flex-plate & Damper Fully Balanced /
    Hastings Plasma Moly Rings / King Con-rod bearings / King Main Bearings
    Holley Street Avenger 770cfm (needs new Electric choke case, very low mileage carb, very clean)
    ARP 4 Bolt main kit
    Comps Camshaft XE274H
    Comps Magnum Double Roller Timing Set
    Comps Block Hardware Kit
    Brass Core Plug Kit
    Mr Gasket Cam bolt Lock kit
    Melling Oil Pump
    Melling Oil screen
    Fram Oil Filter
    Milidon Balancer Bolt Kit
    Moroso Fuel Blank Plate
    Full set of New Hydraulic Tappets
    Fel pro one-piece Oil pan Gasket
    Chrome Oil pan
    Alloy Timing Cover
    Full Stainless Steel Engine Bolt Kit
    New Edelbrock RPM AIR-GAP Manifold
    New Alloy Polished water pump
    Moroso Water pump extension kit Short-to-long
    2 x 160 degree thermostats
    New High Torque Mini starter Kit with bolts
    1 x Billet Dipstick 1 x Standard Dipstick
    Manifold Vacuum Fitting
    Fuel pressure Fitting
    Chrome Alternator Bracket
    Lower Gasket Set
    Fel pro Valve Cover Gaskets
    Manifold vacuum seal Fittings
    Spark Plug indexing Washers
    Carb vacuum plugs
    Mr Gasket Timing Tab
    Mr Gasket HEI Advance Kit
    Mr Gasket Lead Separator Kit
    Comps cam Oil Break-in Additive
    454 Chrome valve Covers
    Good Set of Hedman Exhaust Headers with 3'' Collectors
    Original set of Low Mileage 454 Peanut Port heads Supplied.
    Great Spec Big Block for easy 500bhp+
    Ready to Assembly, only needs Distributor, Flex plate Bolts, Leads,
    Spark Plugs and a Good set of Heads to be a real powerhouse in any street Machine.
    There's many low compression Stock Big blocks floating around on eBay, but this Combination is capable of 500-700bhp
    with the right set of Heads, Excellent street Compression for Edelbrock & Pro comp Cylinder Heads,
    Taken along time to peace together, so not going to Accept silly offers.
    For the Buy it now price of £3750
    I will build the Bottom end for the New Owner.
    I Can Deliver at Buyers Cost.
    Cash on Collection or Paypal.
    TEL:07972025719
    [email protected]
    www.publicenemycustoms.uk
    1. Big block heads (chevy 454)
      By Dr_evil in forum Stuff - WANTED
      Last Post: 16-02-2014, 19:07
    2. Chevy big block 454 piston and conrods wanted
      By Garrylogan in forum Stuff - WANTED
      Last Post: 23-06-2013, 12:49
    3. new ceramic coated headers fit big block tri chevy
      By BookhimDanno in forum Stuff - FOR SALE
      Last Post: 29-04-2013, 21:14
    • You may not post new threads
    • You may not post replies
