32 Chassis
Model A front crossmember
Original Model A rear crossmember
Original 1932 K crossmember adapted for T5 gearbox
Flathead v8 mounts
Early Ford pedals with new rubber pedal pads
Brake master cylinder
Rear brake lines fitted with 3/16" pipe and residual valves for front/rear
Front/rear spreader bars (stainless) - All parts above come with the chassis - Chassis now Sold
Original 1932 Heavy axle, spring and unsplit wishbone and spindles, new U bolt kit, adaptors for juice brakes and new king pin kit, 1932 repro track rod and drag link including ends with eurathane bush kit, Stainless steel upper and lower shock mounts, Stainless perch bolts, new front shocks - £1400
40's juice front brakes, complete, cleaned and ready for paint - SOLD
40's juice rear brakes, complete with new wheel cylinders, cleaned and ready for paint - SOLD
1934 Ford steering box, column, pitman arm and column cover - £150
1939 Ford rear axle, closed drive (no torque), P&J ladder bars - £500
Rear shocks and lower shock mounts - £70
Original Model A rear spring, stainless shackles and original u bolt setup - £100
Look on my website for loads of pictures Thirtieshotrod.com - Clarky's diary on his Hot Rod Experience
Collection from Waltham Abbey, Essex, J26/M25
Thanks
Michael
Flathead v8 mounts
Thanks
Michael
