Ford 351W engine.
View Entry Info: Ford 351W engine.
Category:
Classifieds 1 Item (All details are required to post items in this section.)
Price
3000
Lowestoft
Condition of Item
Engine rebuilt less than 1000 miles ago.
Description
Tuned
Results 1 to 2 of 2
    Mar 2015
    Lowestoft
    57
    2
    Woodsyv12 is offline
    Ford 351W engine.
    I built this engine last year for my van but took it out again when I sold the van to use in another project. It had done less than 1000 miles.DSC_0048.JPGDSC_0052.JPG
    Plans now changed.
    Engine details.
    1972 351w v8.
    Block acid stripped and chemically cleaned internally.
    Modified to be fitted with a lip type rear crank seal, so no worries about rear crank seal leakage.
    +40 rebore.*
    Crank reground, mains and big ends.
    Full engine internal balance.
    New Hyperutectic pistons and ring set.
    Double roller adjustable timing gear set.
    New oil pump.
    Comp cams duel energy 265Zdeh camshaft.
    Comp cams lifters.
    Velcro gaskets.
    New Elelbrock I let manifold.
    GT40p cylinder heads, ported.
    New valve springs and retainers.
    Pro comp roller rockers.
    Pertronix ignition unit and adjustable ignition vacuum advance.
    Engine runs great with lots of power. I can run it to demonstrate.
    Starter and manifolds come with the engine.
    I also have a good used water pump and crank pulleys.
    Sump has been modified to hold more oil. Not the tidiest of jobs and the rivets that hold the original dipstick tube weep *very very slightly (I have silicone over the rivets which stopped it but now the engine is out it would be the ideal time to sort).
    I want to keep the carb but have an emmision Holley 4 barrel that can go with it if wanted. I will have some other bits and pieces to go with it too.
    Mar 2015
    Lowestoft
    57
    2
    Sold.
    1. Ford 302 and Ford 351w engines for sale
      By lead foot in forum Stuff - FOR SALE
      Last Post: 05-06-2011, 20:46
    2. Ford 351W engine and TH400 Tranny
      Last Post: 25-08-2010, 08:36
    3. Ford 351W and bits
      Last Post: 21-03-2010, 23:05
    4. Ford 351W Gasket Set
      By Zody in forum Stuff - FOR SALE
      Last Post: 20-03-2010, 09:39
    5. Beautiful 370 HP Dyno Tested Ford 351W for sale (video link)
      By Flemming in forum Stuff - FOR SALE
      Last Post: 29-01-2010, 22:06
    • You may not post new threads
    • You may not post replies
