Ford 351W internal engine parts
View Entry Info: Ford 351W internal engine parts
Category:
Classifieds 1 Item (All details are required to post items in this section.)
Price
Ł500 ono
Doncaster
Condition of Item
Used
Description
Good working condition, low miles
Results 1 to 3 of 3
    Mar 2015
    Doncaster\South Yorkshire
    77
    Dmsvenom is offline
    Ford 351w small block 1995 block
    5.8Litre V8
    Short block complete with :-
    Eagle SIR5956FB I-Beam Conrods
    Keith Black Hypereutectic 0.060" overbore pistons with low friction rings
    Summit External Harmonic damper
    Crane or Comp cams camshaft (i cant remember which)
    All pistons, rings, conrods weighed and matched to suit each other, dynamically balanced by EDA in Castleford.
    Reground Ford crankshaft
    Named oil pump, rear oil strainer / pickup
    Ford Racing rear sump
    Named cam chain and gears
    Standard 351 push rods
    Motorcraft water pump
    All bearings and shells in engine
    No heads or rockers
    No flywheel
    No clutch
    The block is believed to have a crack resulting in pressure building up in the coolant circuit, so olnly selling for spares / repair. All internal parts are sold as very good with less than 200 miles on them all (except for original crank).
    Engine stll assembled, will split, but would prefer engine to go assembled.
    Picture taken before engine was rebuilt.
    Oct 2014
    MIDDLESEX
    137
    Mini_exo is offline
    Pmed
    Mar 2015
    77
    Dmsvenom is offline
    1. Hot Rod Mirrors internal and external
      By randrhotrodimports in forum Stuff - FOR SALE
      Last Post: 18-08-2011, 18:44
    2. Alternator internal regulator 65 Chrysler
      By boomboom in forum Stuff - WANTED
      Last Post: 03-03-2011, 21:51
    3. tpi fuel pump external or internal ?
      By Crookes37ford in forum Tech Discussion
      Last Post: 01-03-2011, 23:25
    4. Replies: 2
      Last Post: 26-11-2010, 23:15
    5. 100E internal door parts
      By Gasolinescream in forum Stuff - WANTED
      Last Post: 18-08-2010, 21:55
    • You may not post new threads
    • You may not post replies
