pair of narrowed 8/9 inch ford small bearing shafts 42'' wide 5 stud ford UNSPLINED
Results 1 to 1 of 1
    Official RnS Addict Nobler's Avatar
    london
    1,312
    150
    Nobler is offline
    pair of shafts, been cleaned and painted.
    cut so as to acheive about 40 inches to flanges
    centred pinion 'not case'
    they have been spun down on a lathe, they have the rebate after the splines =just need the splines put into them
    ideal on a pop - if you want a centred pinion, i wanted an off-set pinion, for diagonal top bars, so changed over
    this is what you get fitted to a pop with 10 by 15 torque thrusts, the ones with equal in and out -bearing weight transfer/loading.
    they are stock shafts, @ 5 on 4.5'' pcd
    they come with some mock up nylon bearing spacers, so realistically you could go and find yourself a mustang 2 -as pictured 8 inch case,
    chop it up as above fit the shafts in and see where you are.
    the flanges have also been spun down so they fit into a ford probe/mazda 6 rear disc, solid 10mm, on which ythe sierrar/granada-all modern calipers really, work well - you will have to enlarge the holes in the 4.5'' pcd from m12 to 1/2''
    the postage on a pair of shafts is about £20
    for sale at £25 the pair, note I gave the precision engineer £100 just to spin them down!!!!
    steve 0774 858 2044.
    if my memory serves me correctly, the long one is 505mm, the short is 400mm - i can check
    plus 35mm for diff = 940mm = 37 inches , plus an inch for discs
    they are about 38 inch wide then!!!
    1. Replies: 0
      Last Post: 11-11-2011, 12:01
    2. Replies: 0
      Last Post: 01-11-2010, 14:46
    3. Replies: 0
      Last Post: 01-10-2010, 13:12
    4. pair of mopar 4" x 5 small stud slotmags £60
      By vin likes diesel in forum Stuff - FOR SALE
      Last Post: 15-02-2010, 15:54
    • You may not post new threads
    • You may not post replies
