12V electric fuel pump
Results 1 to 2 of 2
    Oct 2011
    wicklow ireland
    408
    64
    shagedemus is offline
    I'm looking for a 12V fuel pump suitable for a 350ci SBC with a 4 barrell carb.
    It's in my van and despite putting a one way valve at the tank end it still takes too many cranks to get the fuel all the way from the tank to the engine.
    Failing someone having one for sale on here, Is there one of a modern car that is generally used on rods and is easily sourced from a scrappers?
    Cheers.
    13,270
    i've used a facet red top pump on lots of yank v8's. if they can feed a rally car with twin webers doing 7/8mpg then they'll do the same for a v8. with a holley carb you can get away without a regulator, if using an edelbrock carb then you'll need to reduce the pressure a bit to avoid flooding with a regulator.
    • You may not post new threads
    • You may not post replies
