105e Back axle
Results 1 to 4 of 4
Thread: 105e Back axle
    Jul 2010
    Smallfield Surrey
    321
    wrench is offline
    105e Back axle
    Can anyone advise me on this back axle
    I am building my son his first hotrod a 1953 pop, which while be powered by a 1500 spitfire engine.
    I have a viva front end with 2.8 capri vented discs and XR3 breakes.
    We have been offered two 105e back axles one is from i think a 997 power plant and the other is from a 1200 power plant. The 997 is complete, but the one from the 1200 is missing the break drums and some wheel studs.
    My question is which one of these would be best or dose it not matter, and are there other break drums that will fit this such as escort or cortina ?
    Wrench
    Banjo snapper. Hemi Bucket's Avatar
    Knocking one out.
    3,507
    998
    Hemi Bucket is offline
    If neither axle has been mucked around with, the 997 will have a 4.44:1 diff, the 1200 will have a 4.1:1. This is a general rule, you might get some smarty bottom pipe up with options for estates etc, but it's a good guide. Just about any Fords drum set ups will fit, you often have to redrill the backing plates though & rotate them on the axle case to get the handbrake linkages to line up. If you use Capri brakes, you have to mix & match a bit as the halfshaft offset's a little out from memory. Corsair or Cortina GT used to be the hot set up as they have 9" brakes, they're not cheap anymore though.
    The wheel studs aren't a problem, they're the same across the whole range as long as they're Imperial, I've got gobloads here if you get stuck, think I've got some Anglia/Mk1 Cortina brakes somewhere too. PM me if you get stuck.
    Edit, Just seen where you are, I work out of Manor Royal so could drop the studs in to you.
    How'd the weekend go? Well, at the moment it looks like a dolphin that's been caught in a boats propeller.
    Jul 2010
    Smallfield Surrey
    321
    wrench is offline
    If you work on Manor Royal then you might no my factory.
    We are the blacksmiths next to Charlies deli on Gatwick road ( Happy Hedgehog wrought iron)
    Drop in for a cuppa and a chat.
    Brian
    Flange Dealer Paul G's Avatar
    Derby , UK
    642
    57
    Paul G is offline
    1200 drums are wider than 997 , certainly on the front , not sure about the back though , it's been a long time since I mucked about with stock Anglia parts. I may have some drums in the garage. The rally boys used to want the 4.44:1 diffs & would pay good money for them at one time. It might be worth noting that van axles are about 1.5" wider than saloon & the half shafts are not interchangeable although the diffs are.
    1. original pop back axle
      By bod in forum Stuff - WANTED
      Last Post: 23-04-2010, 21:22
    2. 1/25 Jag back axle.
      By insanityvans in forum The Shelf
      Last Post: 29-03-2010, 16:20
    3. 105e Rear Axle
      By matt100e in forum Stuff - WANTED
      Last Post: 08-12-2009, 17:45
    4. anglia 105e rear axle wanted
      By crumble in forum Stuff - WANTED
      Last Post: 06-11-2009, 16:17
