12 volts to 6 volts
Results 1 to 10 of 16
    Jun 2011
    Keeston, H/west
    1,381
    799
    Perfect65 is offline
    12 volts to 6 volts
    I have done a few conversions from 6 volts to 12 volts and these work fine in the main. Last one I used a 12 volt battery with a 6 volt tapping put on by the battery maker. The 6 volts were just for the fuel gauge and the semaphore solenoids. All worked automatically with relays. I even got the semaphore bulb flashing. Moving on, I want to do away with the 6 volt tapping so I can use a modern sealed battery without the lead bars on top. I have been looking at 12v to 6v regulators using a power transistor and a few other electronic bits. Has anyone here had any dealings with such a regulator or made one up? I have an article by Steve Delanty which spells it out pretty clear and describes one that will cope with over 10 amps which should cover my solenoids but before I go ahead and make one - is there one on the market at a reasonable price?
    Dave
    www.53catalina.co.uk 53catalina's Avatar
    southampton
    2,454
    76
    1316
    53catalina is offline
    You can certainly buy droppers for the fuel gauges. I think demon tweeks supply them, as well as most vintage car supply dealers.
    You can buy heavy duty ones for the lights and heater motor, but i have never used one myself.
    Jun 2011
    Keeston, H/west
    1,381
    799
    Any suggestions on where to get the heavy duty ones?
    Rods 'n' Sods Junkie Grumpy Grandad's Avatar
    Dec 2012
    South
    469
    37
    Grumpy Grandad is offline
    Not sure you can buy something off the shelf but If you can do minor electronics you could easily make something up that will do the job. Parts from RS components , Maplin , Ebay
    You could use an IC from Maplin rated at 2 amp L200C Adjustable Voltage and Current Regulator : Voltage Regulators : Maplin Electronics
    Or a zenner diode and ressistor will do the job, probably best to have one circuit for each load. We used these to switch idustrial transmission solenoids and proved very reliable.
    Zener Diode Voltage Regulator - Electric Circuit
    Steve
    Jun 2011
    Keeston, H/west
    1,381
    799
    Quote Originally Posted by Grumpy Grandad View Post
    From what I have gleaned so far, it seems that in order to cope with about 10+ amps the circuit would need a power transistor. I think the transistor is controlled by a voltage regulator like the zener. What do you think? I am no electronics engineer but I think I would be able to put this together but if I could buy something ready made I would go for that. I am on the verge of taking myself to Maplins. I read an article on the net by Steve Delanty titled 6 to 12 to 6.
    Rods 'n' Sods Junkie cymrodder's Avatar
    Feb 2011
    anglesey, north wales
    151
    cymrodder is offline
    I purchased a voltage drop from LMC Trucks for my fuel gauge, seems to work ok, I know that Pop Browns stock two versions but I can't remember the explanation to which unit was best for what purpose.
    Jun 2011
    Keeston, H/west
    1,381
    799
    Quote Originally Posted by cymrodder View Post
    I just checked on the PopBrowns catalogue and the volt droppers are for gauges so dont cope with the current I need for the semaphore solenoids. I am thinking maybe better I stay with the 12 volt classic style battery with exposed straps on the top and have a 6 volt tapping fitted as I have done before - so much simpler. But, in the meantime I will make one of the high current voltage control units as described by Steve delanty and report back here. Cheers, Dave
    Jan 2011
    GLOUCESTER
    891
    29
    nikb is offline
    couldnt you use a LM7805 with a diode on the middle leg and then a 2n3055 to give you some current (bit basic but cheap as chips)
    Aug 2011
    surrey
    1,662
    19
    robo1 is offline
    Why not use a couple of modern six volt batteries in series and you can tap off the one like you already have.That gives you both the 12 and 6 volt posts . Just thoughts.
    bob
    Jun 2011
    Keeston, H/west
    1,381
    799
    Quote Originally Posted by robo1 View Post
    bob
    Yes I know what you mean but I think this is similar to the 12 volt battery with a 6 volt tapping but this idea ok if the battery doesn't have exposed bars on the top. Thanks for that - will submit to the committee. Dave
