240 to 12v
Results 1 to 10 of 10
Thread: 240 to 12v
    nowhere
    7,033
    2406
    nobody is offline
    240 to 12v
    One for the electrical folks.
    To get cars onto my table I have car ramps and a 12 volt winch.
    I connect the winch up to a battery,which is ok if the battery is fully charged.
    Is there some way of hooking up the winch to a mains supply,so I don't use a car battery.
    This isn't something that's used every day,just once every few weeks
    Official RnS Addict rockhouse's Avatar
    Dec 2010
    clacton-on-sea
    952
    54
    rockhouse is offline
    depends on the amps it draws
    you could use a large power supply
    like they use for amateur radio
    Jun 2016
    Roswell, New Mexico
    840
    NMNeil is online now
    Due to the high current draw my first though was a lithium battery starter pack.
    Very useful to have around at any time.
    https://no.co/products/power/jumpstarters
    I'm a grown up member now ! Wolselliac's Avatar
    Aug 2009
    Reading
    66
    20
    Wolselliac is offline
    //www.rodsnsods.co.uk/forum/asset.php?fid=247421&uid=1021&d=1589120327. Use a Gunson battery Charger/Starter, mine can start the engine with a flat battery after only a few minutes.
    And if I still worked in Feltham, I'd have brought mine over for you to try it out before you went ahead and bought one.
    nowhere
    7,033
    2406
    nobody is offline
    Are the little starters only good for one go.the winch runs for a couple of minutes.
    The bigger one would work.
    Though like a normal battery would need to be charged fully to work the winch.thats the problem ,because most times I need to use it nothings charged fully.i do have three phase at home
    Rods 'n' Sods Junkie alleykat's Avatar
    Apr 2013
    High Wycombe
    171
    alleykat is offline
    I used to have a 12v fridge in my old van that ran off the fag lighter, you could also plug it into a inverter / converter thing that was mains powered, just plug n play. Would something like that work ?
    Lifes to short to worry about tossers
    It's ok to not be ok
    Milton Keynes
    1,007
    16
    Magman is offline
    How about switching to a 240v winch, it may be easier in the long run
    https://www.winchmax.co.uk/categories/ac-winch
    9,076
    1772
    blackpopracing is offline
    Have a look at the tag on the winch to see what the current rating of the motor is. Then look for a 240/12v power supply unit with about 50% higher rating.
    This one would probsbly be ok at 30 amps; https://gimsonrobotics.co.uk/categor...r-power-supply
    or this one from TLC in slough, https://www.tlc-direct.co.uk/Products/SK650662.html
    Same place for a 40 amp, https://www.tlc-direct.co.uk/Products/SK650664.html
    Jun 2009
    Rayleigh Essex
    3,166
    287
    trevd is offline
    I picked up a 240 winch from lidle, was about £70 and worth every penny, I have vertically lifted a big block mopar and auto box with no problem so should do what you want with no problem.
    Rods 'n' Sods Junkie Andy650's Avatar
    Oct 2013
    Eastleigh
    115
    16
    Andy650 is offline
    How about a cheap trickle charger permanently wired to a dedicated battery. That way you know its always ready to go
