302 efi
Results 1 to 4 of 4
Thread: 302 efi
    Jul 2009
    havant,hants
    440
    21
    paddy is offline
    302 efi
    I`ve got an 1987 econoline day van with a 302 EFI in it and it runs like a dream.What I want to know is can I play with that engine, put a cherry bomb on the exhaust without messing the fuel injection up.Some one mentioned a lambda sensor on the exhaust which may be effected by making it straight through also whether i could swap the heads for higher compression ones.Basically I want to know if i am limited in anyway by the EFI set up to make alterations/modifications to the engine if i wanted to.There is of course that choice of it going into something else another day,does everyone scrap the injection set up and put a carb on ? I`m sure there must be some up grades that can be made to get it to perform a bit better,it does ,for what it is,quite well on the fuel consumption but it does lack beans, or rather needs more of them.What are your thoughts, cheers guys
    If it bleeds, we can kill it.http://www.supermotors.net/21407
    Cheltenham
    4,076
    601
    fozwanger is offline
    It all depends on how complicated your efi is.
    In theory, reducing the exhaust back pressure shouldn't and probably doesn't make any difference, and to all intense and purposes upping the cr shouldn't affect it too much either.
    As you are still squirting in the same ampunt of fuel and air respectively the various sensors should inform the ecu and the system should cope.
    However.......... American efi set ups and their smog bilge and other things can prove to be a mine field and open up a right can of worms.
    Rather than get high comp heads youd be better off investing in an aftermarket ecu that you can program yourself and tweek at your liesure (although you can'y beat having it set up on a rolling road.
    Ask about on the mustang forums as the guys with the fox types are playing with them all the time.
    Also depends what type you have, MAP, MAF (hot wire) etc etc. so there's plenty of research to do
    Jul 2009
    havant,hants
    440
    21
    paddy is offline
    Cheers,
    i had a feeling things might not be as easy as first seemed.As I say it`s an 87 which i hoped would mean being older could mean being easier.I` ve never had an efi set up on a vehicle before, had plenty of pressure fed bosch systems and they used to compensate for quite a lot of alterations.On the flip side though you think it may be possible to make improvements by changing an ecu.That just sounds to easy.I`m glad I asked and perhaps some one else may be able to shed more light on the subject Thanks Fozwanger
    Lee
    Fat 'n' Loud Lee's Avatar
    Derby
    4,766
    493
    Lee is offline
    I've got a '91 Mustang with EFI and I've dumped all the emissions crap and fitted a free flow exhaust and one or two other bits and bobs with no problems.
    As long as you don't start messing with the injection system too much you should be OK.
