302 ford probs
Results 1 to 10 of 12
Thread: 302 ford probs
    Rods 'n' Sods Junkie fluff's Avatar
    Sep 2009
    south cerney glos
    274
    23
    fluff is offline
    302 ford probs
    hi there,
    i went to start the ford up this afternoon and bang there was a loud thunk and the motor shook violently for 2-3 turns then siezed solid with a puff of blue smoke out the left exhaust the motor will not turn on the starter or a socket on the crank. before i pull it apart any ideas as to what happenedi was thinking a dropped valve or a snapped con rod not looking forward to the bill
    yours cheesed off rich
    I'm a grown up member now ! pussy's Avatar
    Jan 2010
    london
    78
    14
    pussy is offline
    take the plugs out that side see if there is any damage to the plug it will tell you that cylinder might be the one
    "call 0-800 Apocalypse" satan's Avatar
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    Quote Originally Posted by fluff View Post
    hi there,
    is it outside,? any anti-freeze in it,? if no. could be cracked somewhere,
    if yes,and its not frozen, try removing the starter then try turning with a socket,
    is it a strong running motor, or a tired old thing thats on its last legs,?
    And I heard a voice in the midst of the four beasts, And I looked and behold: a pale horse. And his name, that sat on him, was Death. And Hell followed with him.
    Sep 2009
    south cerney glos
    274
    23
    fluff is offline
    antifreeze was sorted at begining of november the motor was strong ie no smoke on startup and running 50psi oil pressure going to take plugs out and starter off tomorrow night
    Official RnS Addict 1968unclefester's Avatar
    faversham kent
    688
    454
    1968unclefester is offline
    as above, try with starter removed first it may be a seized starter
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    a mate had a 302 windsor a while back that snapped the timing chain and locked solid, mind you it was a totally worn out motor that got through more oil than gas, when he pulled it apart the chain had almost worn through the timing case,
    hope you sort it, good luck.
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    hi there,
    anyone know what the findings were,??
    Sep 2009
    south cerney glos
    274
    23
    fluff is offline
    302 ford probs
    sorry for the wait but computer problem added to the expence of sorting out the 302 first i took the plugs out and found that no 5 and 8 were wet as in water took the inlet off then the heads bloody head gaskets on both sides were shot lucky though it had antifreeze so there was no rust on the bores fitted new gaskets and reground valves and fitted new springs and collets refitted heads and inlet with new gaskets changed oil (which was clean) and fitted new filter now every thing was back together time to start up because i'm using smithy mufflers and they had water antifreeze mix in them when it started it filled my workshop with steam took it for a run and got stopped by the rozzers but after explaining to them it was steam and not smoke from the zorsts and that it will clear i was told to go so now the old girl runs sweet again and i am skint
    christmas is almost here theres 18 inches of snow and im going to open a bottle of jack
    thanks for any help
    rich
    Nov 2009
    stourport
    5,529
    7
    beach57 is offline
    That could have so much worse.
    Jun 2009
    1,802
    v8ian is offline
    Hydraulicly locked engines engines can cause a lot of problems that go unseen, normally bent conrods, and can be bent on turning with the starter as well, Im not saying yours will be bent but its can happen
    1. 302 Ford V8 & C4 Auto Parts
      By cushti in forum Stuff - WANTED
      Last Post: 10-12-2010, 13:20
    2. 289 or 302 ford engine & box
      Last Post: 27-01-2010, 14:37
    3. 302 Parts wanted and 4 stud ford wheels
      By lumpy_idle in forum Stuff - WANTED
      Last Post: 02-11-2009, 21:21
    4. Wanted Ford 302 V8
      By Devon1288 in forum Stuff - WANTED
      Last Post: 29-10-2009, 13:06
    5. ford 302 motor wanted or shortblock
      By GT350 in forum Stuff - WANTED
      Last Post: 20-09-2009, 19:58
