351w blower engine
Results 1 to 10 of 11
    Official RnS Addict speedfreaks's Avatar
    May 2011
    acocks green/ birmingham/ west mids
    1,364
    203
    23
    speedfreaks is offline
    351w blower engine
    Hi all went to stateside and got a engine block that going to have and also got another might buy as a spare in future also a c6 aswell for me.
    The thing is what would like your help with is he said his a dealer for summit racing so can order anything through him and don't pay the charges then. So just need your help in what I need to buy.
    I want to keep it to a 357w so will be +30 forged pistons with standard height rods and crank. But with doing that what dish of a piston would I need and what cc combustion heads do I need to keep the compression to around 8.5 or 9.0?
    Also would I buy the balancer now or weight till it's balanced to find out what one I need to buy?
    would a full fel pro set of gaskets be best to buy?
    Will get arp full set. And slosh tray and so on for the oil pan to help keep the bottom end from over loading in oil and so on.
    Would just a standard flow water pump be best for using on the road?
    O what cam would I need to get duration and lift would be best?
    Will get the twin chain timing chain.
    And if get them now what carbs would be best got fuel lines for double pumper I think as goes for two outlets on two separate lines and then a joiner also from bds think for holleys?
    Also what dissy would go then with all other bits? I've got a tallish manifold and also a 2" spacer plate from bds so got abit of height to miss dissy.
    If there's anything I've missed let me know please
    Cheers phil
    May 2011
    1,364
    203
    23
    What your thoughts to one of these kits? Thinking about the street fighter kit or the scat one mainly scat as probably a better cast crank than the other only thing is the I beam rods would these be ok still as not looking for that much power anyway and nearly $1000 dollars less than the others. With 64cc cylinder heads to give me a 8.58 compression or 61cc gives 8.82 compression.
    http://www.coasthigh.com/Ford-357-Wi...e-s/130612.htm
    Sep 2014
    The north
    1,365
    1314
    nuggets is offline
    Summit dealer £/$ is more expensive than ordering yourself usually
    CR use the Wallace racing calculator and check but I'd guess 13-18
    Balance it to 28 or 50. You don't really have much choice....either that or buy a fluid one
    Gasket wise cometic or felpro work fine, black felpro or blue will suffice
    Standard water pump or high volume with up rated rad
    Choose a blower cam.....there's specific ones for blown applications
    Pair of 600s or edelbrock vs carbs would work
    Bearings are missing. Clevite p series I think are the top ones. Rings need to be gapped to match piston specs and use the smallest lightest Pistons/ring packs about
    Dizzy a proper billet Petronix or Malory unit or ford racing
    I'd build for 8:1 or slightly lower then you can always up boost later
    May 2011
    1,364
    203
    23
    Cheers nugget.
    In the link they do the bearings use clevite ones and moly pre fit rings I've asked them if can upgrade to clevite tri armour what suppose to be the bests ones they do and if had the total seal gap less rings also so just waiting for them to get back to me with price extra.
    Will go with fel pro as used by everyone really ent they.
    Rad will look at serck one with fans.
    Will look out for cams then and yer thinking 600 carbs also.
    Will go for 8.5 to lower then for comp then cheers mate.
    Also will probably buy unbalanced and then get a engine builder over here to balance it to make sure done right and to put a double key in it also.
    kent
    2,962
    choppedblownpop is online now
    I'd go with all MSD including distributor,you really want the Msd 6-btm for retarding the ignition
    May 2011
    1,364
    203
    23
    Cheers blownpop. Yer will go with that also.
    The other thing is whey out look at the street fighter kit it gives you options to have 28oz balanced with balancer and flexplate but then look at the scat one and the only option for that one says external balance but without any other bit so what would I need to get for just external balance if no options of having 28oz and so on?
    Gear Jammer Mustanglimey's Avatar
    Jul 2009
    Hertfordshire
    234
    Mustanglimey is offline
    I have an internal Powerbond balancer, a step up is the Innovators West. Both go 28 external, internal (neutral) and double key way.
    The owner of Coast High Performance regularly posts on the Corral.
    All 351w are 28oz external, and most kits would be balanced to this. Neutral is better but can be harder, more expensive dependant on crank that's used.
    You buy a zero balanced damper and flex plate ....some of these come with removable weights to offer both.
    Head gaskets id use the Felpro MLS.
    As for cam for a few extra bucks and get a custom Hyd roller. Woody uses Comp, I'm not sure if Bullet cams are still going, but get on the Bullet (yellow) there is good info and recommendations for a cam ground for your application.
    I'd reccommend Ed Curtis @ Flowtech Induction.
    Jul 2009
    Hertfordshire
    234
    May 2011
    1,364
    203
    23
    Cheers Shaun you know bloody loads considering you say you don't build them you should get into that side of things would do well from sounds of it.
    Jul 2009
    Hertfordshire
    234
    Quote Originally Posted by speedfreaks View Post
    Knowing the sum of parts and building an engine are two different entities IMHO.
    As I posted before I ask many questions and try to find what combos work with what. I could pick you a combo built on your budget/goals but final say us left to your experienced engine builder.
    I'm just run what you brunger trying to go fast as I can for my wage so try to max my bang for buck.
    I would never claim to know how to build a sbf but the sum of parts I've a good idea.
    I paid an extra £1000 to go Dart SHP block. This gave me 4 bolt billet main caps on 2/3/4, no cap walk worries on nitrous, a 2.75" main bearing size over the 351w 3" for less friction and rpm capability, and the 4.125 bore size and custom Pistons.
    This unshrouds the valves and of course allows bigger inlet and better power....so a no brainer really for me.
    Id just like you to max your investment. Buying a whole new rotating assembly I'd hit the 408 all day and everyday .....it's no weaker, that's why Woody don't do stockers.
    The old 393 strokers use something like a stock heavy 302 piston and possibly a Chevy style rod....forgot the actual combo but not worth the effort.
    With a sorted chassis and traction your car could haul ass....and whine lol
    1. Replies: 2
      Last Post: 30-01-2013, 19:24
    2. rover engine and blower
      By Fad T in forum Stuff - FOR SALE
      Last Post: 21-07-2011, 09:59
    3. 6v71 blower + SB Ford engine parts. PRICE DROPS.
      By Plumpcars in forum Stuff - FOR SALE
      Last Post: 15-04-2011, 06:19
    4. Ford 351W engine and TH400 Tranny
      By lead foot in forum Stuff - FOR SALE
      Last Post: 25-08-2010, 08:36
