351w non starter
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 71
    Jym
    Dec 2017
    Birmingham
    23
    Jym is offline
    351w non starter
    Hi Everyone,
    It's a fresh motor (8.5 to 1 , rebore and new rings) and is showing about 130psi with a compression test.
    Has twin Edelbrock 1405 Carbs, floats set and all stock jets. Hit the throttle and the main jets are squirting fine.
    MSD 6 which tests out ok (bridge the trigger wires with coil lead earthed)
    Cylinder 1 is set at TDC on compression stroke with the rotor arm pointing at cylinder 1. rotor spins anti clockwise with correct firing order for 351w.
    When cranking it doesn't want to fire. With easy start it'll fire once and die. I've tried cranking and rotating the distributor either way, still nothing.
    Pulled the plugs, they look okay, not wet. Tried hitting the throttle several times to add more fuel, still no good. I have a 2" spacer onto the intake, a 6-71 blower with a 2" carb spacer.
    I'm confused, it has spark, ignition, the carbs are priming and squirting fuel but doesn't want to start? I've unbolted the carbs and raised them to make sure they aren't leaking fuel, they look fine.
    Any advice would be great, thanks in advance.
    May 2016
    S E London
    932
    22
    timbo56 is offline
    Have you checked that you have got a spark at the plugs?
    Jym
    Dec 2017
    Birmingham
    23
    Jym is offline
    Yes, spark at the plugs.
    May 2015
    Somewhere West of London
    136
    2
    Test or Kill is offline
    At this time of year old style engines may need a lot more fuel to get going. Try to make sure the timing is at least close to where it should be and try chucking about 1/2 a cup of fresh petrol down the carbs and then crank it, or just give it a few good pumps on the gas pedal as long as you are sure the pump jets are squirting properly. The fact that you say it runs on easy start is the clue here. HTH
    Cheers, Martin
    Jym
    Dec 2017
    Birmingham
    23
    Jym is offline
    I've always played with EFi engines so this carb business is pretty new to me. I'll try the half a cup of fuel direct into the carb and let you know how it goes.
    Thanks for your advice so far and taking the time to help.
    Jym
    Dec 2017
    Birmingham
    23
    Jym is offline
    Okay, half a cup of fuel it fired up and cut out. reattempted to start and the motor sounded like it was trying to lock up. Another half cup and done the same again. Maybe it just need a tune up, can anyone recommend someone near the Birmingham area?
    Sep 2014
    The north
    1,365
    1314
    nuggets is offline
    Half a cup?? Way too much
    Anyway if you had it apart did you degree the cam and make sure the chain was set right?
    You may also want to check your timing marks
    Should fire and run at 6-12btdc
    Feb 2013
    uranus
    2,299
    ivanhoew is offline
    fresh fuel in the tank ?
    May 2015
    136
    2
    Depends where you are in the UK, you are Oop North, cups are different there. Anyway, it should keep running so sounds like the carbs may not have fuel. Pump working OK?
    Cheers, Martin
    May 2016
    S E London
    932
    22
    timbo56 is offline
    Assuming the cam is timed correctly and the distributor is putting out more than one spark and/or you don't have a faulty box then it'll be ignition timing related, are you sure it's not 180 degrees out (easily dome) and make sure the rotor is pointing before No.1 and turn the dizzy as you get someone to turn the key.
    Any engine should run, even roughly providing you have a spark, petrol and near correct timing.
    One other thing, are there any air leaks inlet side such as unblocked vacuum pipes?
    1. 350 SBC Non Starter
      By road rage in forum Tech Discussion
      Last Post: 17-11-2012, 14:49
    2. Non starter
      By jon100e in forum Tech Discussion
      Last Post: 18-09-2012, 12:16
    3. SBC starter advice
      By boyceeeee in forum Tech Discussion
      Last Post: 16-05-2009, 07:57
    4. well heres another non nsra member lol
      By robford in forum Who are ya ??
      Last Post: 24-04-2009, 21:41
