4 link /bar question?
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    middlesex
    108
    petrolhead is offline
    Question4 link /bar question?
    hiya, i have 30mm clearance between my 4 bars and the inside walls of my tires, do you think this is ok or is it too close, the car is heavily tubbed and things are very tight,what kind of clearance have you guys got and have you had any problems with tires touching the link bars? thanks in advance tony
    __________________
    Jun 2009
    bromley, kent
    1,407
    396
    prostreet70gto is offline
    I have got 18.50x33x15 Mickey Thompson's under the back of my gto, with around 2 inches of clearance on the backside of the tyres from the chassis rails. What you have to remember about a 4 bar setup is the sideways arc which on mine is around 1 1/2 inches at full float and thats with a panard bar to hold it in line at rest. so id say you are gonna have issues unless you can run something other than a panard bar to keep it square
    Official RnS Addict Dragsterbus's Avatar
    Stratford on Avon , Warks
    1,029
    11
    Dragsterbus is offline
    Thats pretty much the min amount you want but it should be ok
    The Intergalactic Custom Shop , Tube chassis and roll cages, Drag cars built, Traditional panel work, Steel and Aluminium Tig welding,Wheeling,lead work,roof chops,Hotrod and Kustom work ,mag wheels wanted
    Official RnS Addict ELECTRIC20's Avatar
    Nov 2010
    SCARBOROUGH, NORTH YORKSHIRE
    560
    599
    ELECTRIC20 is offline
    Quote Originally Posted by petrolhead View Post
    __________________
    Assemble it all together WITHOUT the springs , sit the car on axle stands then move axle ,wheels and tyres in every possible direction , full travel , tilt and diagonally . If it interferes "anywhere" you will have trouble at some point in the future .
    middlesex
    108
    thanks for the responces guys, i have a rose jointed diagonal link between the 2 lower link bars so no side travel on axle during movement up and down, im just worried as im running 29/18.5/15 and i intend on a bit of drag action and im just concerned that when the tires are let down for traction that they may touch .
    prostreet70gto
    have you had any issues when they are low pressure? cheers for your help , tony
    Jun 2009
    bromley, kent
    1,407
    396
    I run with 10lbs pressure for daily driving with no probs. With that size of tyre you hardly notice when they are flat, you notice more when they are over-inflated. Plus they get taller and skinny when racing. I do know people that have had problems when doing oval track racing though, because then you can get side scrub that rubs the inside of one wheel and the outer on the other if the body is near it
    nowhere
    7,135
    2413
    nobody is offline
    hi
    ive read befor that the diagonal link you have is a no no for street use.
    might be worth a little research
    23,736
    Birmingham
    5,791
    57
    40Stude is offline
    hi
    Absolutely correct and I know that loads of people will now say that they have used them successfully for years. Read the links that Kev has posted, they are just two of many from US based chassis shops.
    Nov 2010
    560
    599
    prostreet70gto
    Ur not listening ! Under torque ur "chassis" may touch top of your tyre on initial plant at start line if u dont av enuf clearance !
    Remove ur springs and wobble ur axle !
    Later !
    1. 4 bar link set up
      By xr8 in forum Tech Discussion
      Last Post: 23-11-2010, 02:15
    2. Replies: 4
      Last Post: 13-11-2010, 08:31
    3. langy wants the link to here
      By stumpy in forum Chat
      Last Post: 25-04-2009, 16:32
    4. Have you got the link's effect...?
      By MR1958CADILLAC in forum Chat
      Last Post: 24-04-2009, 11:15
    5. Open drive kit and Pete & Jake Ladder Bar Kit
      Last Post: 22-04-2009, 09:07
