4L60E (Electronic control 700R4) output shaft
Results 1 to 3 of 3
    Rods 'n' Sods Junkie radiogareth's Avatar
    Jun 2010
    Bromley Kent
    265
    9
    radiogareth is offline
    I've got a 4L60E out of a 2005 Silverado (and it's matching L33 5.3) but I'm not using the 4x4 transfer box. The output shaft is shorter than on a RWD box. I have a new 2WD tailhousing and matching output shaft but to fit it the whole box gibblets have to come out of the front.
    (a) Anyone done this or (b) anyone reccomend someone who knows this transmission?
    Located SE London but will travel if needs be..
    TIA
    Gareth
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    Cheaper to get another box I'm afraid had the same issue with a 4x4 700r4.
    Jun 2010
    Bromley Kent
    265
    9
    Hmm, a quick google led to this....
    . Bit of s grim video but you basically pull the front pump out and then remove the circlip (at 6:40). I'd hazard a guess that you dont ned to mess about with the valve body although getting the clutch band back in the right pleace may be 'fun'.
    Once did a T350 by fitting everything in a rebuild kit back in I could. Much to my amazement it worked!!!
    Box and engine have only got 20,000 on them, so unless someone pops up with a 4L60E box for £100, I'll just have to give it a go....
    1. 700r4 and converter
      By Rick57 in forum Stuff - WANTED
      Last Post: 23-08-2012, 08:06
    2. Replies: 9
      Last Post: 23-08-2011, 22:14
    3. Replies: 3
      Last Post: 09-06-2011, 13:08
    4. Shortening Powerglide Output shaft ?
      By WB54 in forum Tech Discussion
      Last Post: 02-12-2010, 17:08
    5. Replies: 0
      Last Post: 04-05-2009, 12:48
