50's yank master cylinder
Results 1 to 6 of 6
    Official RnS Addict scottie's Avatar
    Resin City
    4,009
    1360
    scottie is offline
    its missing :-)
    original one seems to be 1" bore and a sinlge circuit
    i would rather have dual circuit would it be a case of using any 1" bore cylinder ?
    its drums all round
    23,344
    Have a look at Transit and LandRover units . Ignore anything that looks 'short' as they are normally ABS versions.
    You'll need a pair of 5lb residual valves if it is under floor mounted on your car .
    Resin City
    4,009
    1360
    scottie is offline
    standard bulkhead mounted (stock looking)
    Resin City
    4,009
    1360
    scottie is offline
    and no servo
    23,344
    No need for residuals then . Possibly an adaptor needed for correct orientation. Still look at Landrover, just ealrier heavier versions. Otherwise Wilwood .
    12,986
    i've use both of these wilwood cylinders that we keep at work. which i've used depends mainly on the bolt pattern for the car i'm fitting it to. the first can have the reservoirs mounted directly to the cylinder too.
    https://www.rallydesign.co.uk/produc...ducts_id=10444
    https://www.rallydesign.co.uk/produc...oducts_id=4102
