'59 Chevy front stub axles
Results 1 to 8 of 8
    Rods 'n' Sods Junkie Austin Martin's Avatar
    Sep 2011
    Essex
    393
    47
    Austin Martin is offline
    Any one know if the '59 Chevy (car) stub axles are the same as the '57, I've seen a few brake conversion kits offered, some stating that the same kit fits '57 through to '59, others state '59 through to '64; yours sincerely confused dot com!
    Just a passer by as you might say.
    Sep 2009
    Norfolk
    326
    15
    Tiddytime is online now
    Hi There Austin Martin, I have a similar page on here, There's a firm called The Tuning Shop
    down in Redruth Cornwall that sells gm brake discs etc on ebay, they might be able to help,
    I have a 55 chevy sedan with front discs on but they were on the car when I bought it,
    I'm looking into fitting front discs on my 58 chevy brookwood, read my page it might be helpful,
    Nov 2009
    Ol'fordshire
    2,867
    88
    JackGriffin is offline
    Might be worth looking on Rockauto to see if the same bearings, etc., are used on both? There is usually tech info for each part, sometimes with dimensions, but you might have to spend some time hunting and comparing parts. Also, is there an online 'Hollander Interchange' or equivalent? Not sure about '57 but '55 had bearing races, not tapered bearings, and I would have thought they would have changed that by '59 as I think they were always problematic.
    Screw EU
    Sep 2011
    Essex
    393
    47
    Good point, I'll have to look what bearings it has in the hubs.
    Sep 2009
    Norfolk
    326
    15
    Hi There again, I got a pair of used camaro front discs/hubs yesterday from a
    mate to try on my 58 brookwood original front spindles, the camaro hub fits
    but it fouls the stub axle, and the camaro stub axle won't fit my car, my
    mate thinks the camaro parts are about 1970 era, so might look at fitting
    later discs on my original 58 hubs, like Jack Grffin said we will have to
    do a bit more ground work.
    Sep 2011
    Essex
    393
    47
    Thanks for the update.
    Sep 2011
    Essex
    393
    47
    Had a look at the bearings, they are ball(s) interestingly, (well for me anyway) they are adjustable ball races, with a kind of cone inner race in two halves; never seen that before.
    Sep 2009
    Norfolk
    326
    15
    Hi There Austin Martin, I bit the bullet and tried my front disc/hub from my 55 chevy
    sedan on my 58 brookwood to see if that fitted, it did, also caliper bracket fits
    the original 58 stub axle, so gave in and bought a 55/6/7 brake kit, I have fitted
    one side up with new kit and don't see any problems, I wouldn't think there would
    be any difference between 58 and 59 setup, hope this was helpful, cheers Richard.
    1. 65 mustang V8 front stub axles needed please.
      By sukiton in forum Stuff - WANTED
      Last Post: 13-07-2011, 09:43
    2. metal used for stub axles?
      By vin likes diesel in forum Tech Discussion
      Last Post: 17-10-2010, 19:46
    3. Victor FB VX490 rear axle and front stub axles
      By klassicdave in forum Stuff - WANTED
      Last Post: 29-09-2010, 07:33
    4. HA stub axles
      By Howies-Pop in forum Stuff - WANTED
      Last Post: 26-09-2010, 18:19
    5. Viva HA stub axles & steering (for disc brakes)
      Last Post: 26-09-2010, 18:12
