'59 Impala gearbox issue
Results 1 to 5 of 5
    Rods 'n' Sods Junkie Austin Martin's Avatar
    Sep 2011
    Essex
    393
    47
    Austin Martin is offline
    The '59 Impala (purchased on a whim) wont go backwards seems to drive forwards ok, (don't know whether it changes up) it was very low on fluid, and hoped that might be the problem, but topped it up and now it just leaks; is this a 2 speed powerglide? (all appears to be original)
    Just a passer by as you might say.
    Herts
    4,575
    198
    WB54 is offline
    does it move in reverse if you give it some throttle or not at all ? Best to drop the fluid and check the pan, it might have fried reverse gear clutch pack. If the box has been low, have you moved it through all gear positions to fill the convertor and valve body ? You also need to check the fluid with it running in neutral or park.
    6,175
    1024
    English Impala is offline
    Gearbox could be Powerglide or Turboglide. If the shifter is P R N D Gr it’s a Turboglide, if not Powerglide. Early Powerglide boxes were cast iron, later boxes aluminium. Automatic gearboxes are cauldrons of black magic to me so I can offer no advice on the fault though
    Sep 2011
    Essex
    393
    47
    Hi guys, checked the fluid level in N running (hot) needed about 3.5 litres so pretty low, been driving it so think the fluid is circulated, but no movement in reverse no matter how hard I rev the engine!; gear shift says PRNDL and whilst I haven't been right under the car, it looks like a lump of cast iron
    Herts
    4,575
    198
    WB54 is offline
    if there is no debris in the pan to indicate damage to a clutch pack, no issue with the linkage and it drive in other gears, i’d say it likely either adjustment of the reverse band or replacement of the servo seals which actuate it.
    1. C4 gearbox issue's
      By kro in forum Tech Discussion
      Last Post: 09-04-2016, 18:32
    2. Replies: 7
      Last Post: 13-06-2009, 20:43
    3. dodge dart mopar small block auto gearbox
      By grubster1433 in forum Stuff - WANTED
      Last Post: 05-06-2009, 17:00
    4. Gearbox ecu
      By Evil McNasty in forum Tech Discussion
      Last Post: 23-05-2009, 10:07
    5. 1960 Impala
      By English Impala in forum The Showroom
      Last Post: 25-04-2009, 23:00
