700r4
Results 1 to 10 of 11
Thread: 700r4
    wanborough wiltshire
    699
    roofer is offline
    700r4
    I am just about to mount my 700r4 box to my sbc350, i have a Painless wiring lock up kit & TV cable,
    Is there anything else i should do to this box before i us it,
    Gearbox No onpm045c 8863549/md83 27 spline (later box i have been told)
    Thanks
    Official RnS Addict ALS57's Avatar
    London
    1,226
    169
    ALS57 is offline
    pre-fill the torque converter
    699
    roofer is offline
    Is there anything I should do whilst I have the pan off when I fit the lock up kit,
    nottafukinchancingham
    7,847
    57
    Torment is offline
    new filter cant hurt it.
    57 chevy wagon.
    540cui altered.
    I'm a grown up member now ! americanautomatics's Avatar
    Nov 2013
    Southend on mud, Essex
    96
    4
    americanautomatics is offline
    The TV cable is the most important bit. It raises pressure as engine load increases with throttle opening.
    If you have the cable attached then pull it in and out and make sure the plunger valve is not stuck and operates smoothly.
    You may also want to make a visual note of the cable travel so it looks familiar when you do the adjustment at the carb end.
    If the TV cable is not set correctly you'll get about 30miles before its wasted the clutches.
    Make sure you have the correct TV cable adapter for your carb type, otherwise its fabrication time.
    Jon
    Oct 2012
    South London/NI
    2,158
    721
    Stude Star is offline
    Yes as above, do you have the correct TV bracket? It's the bracket that holds the throttle cable and TV cable to the carb, the two cables don't arc at the same rate so that the TV is 'all in' before the throttle (from memory). What carb are you running?
    Also I presume you have a 4 speed shifter?
    Nov 2013
    96
    4
    Also - apply some fluid to the converter shaft and propshaft seal areas so they dont dry start and wreck themselves. Stick around 5 litres in the box, start up and idle only for a while to let the parts lube themselves. Stick your foot on the brake and run the gear shift through all positions, leaving it in each one for a bit to bleed air from the parts. Keep topping up in 'Park' until full, then road test.
    Re - Gearbox No onpm045c 8863549/md83 27 spline (later box i have been told) - the number is 0NPM045C, the M means its 90's the leading zero means it is a 199'0'. The splines for this year are 30 so you must be counting the rear shaft which are always 27. So yes you have a later 4L60 box. Just for info.
    699
    roofer is offline
    E
    Quote Originally Posted by Jonnyblue82 View Post
    only problem I have is that I will be breaking in a fully rebuilt 350, so I will need to run in for 20 minuites, the gearbox has been unused for at least a year, I have tv cable and bracket etc, have read up on setting up the tv cable but that dont stop me having concerns about getting it right,
    thanke everyone for your advice,
    Nov 2013
    96
    4
    Totally understand where you're coming from.
    The 20 min breakin can be done in stages. The above 2000 rpm break in is to get sufficient crank splash lubrication to the camshaft whilst it beds in to the lifters.
    It wont hurt to allow the engine to idle for a few short bouts as your cam should be reasonably pre-lubed.
    Maybe a good extended crank over with the plugs out will be sufficient to get oil round both.
    The setting of the TV cable is for the 'driving' bit so you can start up ok even with it disconnected.
    Dec 2012
    winsford
    343
    221
    boblester40 is offline
    Change the lockup soleniod if it has not been changed already, make sure you have the right lockup torque converter also .
    1. 700r4 and converter
      By Rick57 in forum Stuff - WANTED
      Last Post: 23-08-2012, 09:06
    2. Replies: 0
      Last Post: 05-08-2010, 10:53
    3. Bolts for SBC/700R4 box?
      By zephyr in forum Tech Discussion
      Last Post: 15-06-2010, 21:19
    4. 700r4 gearbox
      By carl p in forum Stuff - FOR SALE
      Last Post: 28-04-2010, 20:09
    5. Th350 vs 700R4
      Last Post: 11-01-2010, 17:56
