70's Ford steering coupler woes!!!!!
Results 1 to 3 of 3
    I'm a grown up member now ! CraigH's Avatar
    Sep 2009
    Derbyshire
    36
    6
    CraigH is offline
    Has anybody got any experience of changing the steering coupler(rag joint) on a 70's Ford. I recently got my 1977 Thunderbird on the road after a 20 year lay up, she's shown in the showroom in the thread SHE'E FINISHED, MOSTLY!!!.
    She passed the MOT about 3 weeks ago but since then she has started to get play in the steering. Have investigated today and found that the joint between the steering column and the steering box has collapsed. I believe it is called the steering coupler or rag joint.
    I have tried to remove the joint and have got the 2 nuts off and the pinch bolt out and have dropped the steering box to allow me to pull the joint apart. Not sure now how to get the remains of the rubber/nylon from round the 2 dowels as it is held in place by a retainer and I cant figure out how it comes off. I have tried brute force and ignorance but for once this hasn't done the trick. Looking now at removing the column from the car to do the repair on the bench unless anyone knows better. Also what sort of job is it getting the column out.
    thanks
    CraigH
    Some people are like Slinky’s. Pretty much useless but make you smile when you push them down the stairs!!!!!!
    Leicester
    5,696
    594
    bigyellataxi is offline
    They normally come out complete, i.e. two pinch bolts, one on each side (box and column).
    You can usually get away with wedging a screwdriver into the slot to aid getting it off the column.
    I am talking about UK cars so I might be giving you bad advice...
    Fueled by Jim and Luckies.
    Sep 2009
    Derbyshire
    36
    6
    CraigH is offline
    Have now sorted this. Ended up taking the column out of the car which was a lot of fun but it made changing the joint easier in the end. The joint that had fallen to bits was a rubber donut but the rest of the joint is designed in such a way that you can never lose the steering, just get loads of play.
    In the states you can buy a new universal fit donut but a lot of guys prefer to use conveyor belting of the correct thickness as it has the reinforcing in it. Living in an old mining area pit belting is available so that is what I have used. It's definitely taken all the play out of the steering and it is more durable than the un reinforced rubber donut that I took off but I will keep an eye on it.
    1. Replies: 0
      Last Post: 08-04-2011, 15:29
    2. ford steering pump
      By justford in forum Tech Discussion
      Last Post: 09-09-2010, 17:40
    3. Wanted: D Joint Steering Coupler
      By 31ModelA in forum Stuff - WANTED
      Last Post: 09-06-2010, 12:40
    4. 1940 Ford Steering Wheel
      Last Post: 01-02-2010, 19:06
    5. Original 1932 Ford steering wheel wanted
      By Deuces Wild in forum Stuff - WANTED
      Last Post: 12-01-2010, 15:54
