'72 Nova died on me..
Results 1 to 10 of 10
    I'm a grown up member now ! Alex-Nova396's Avatar
    Nov 2013
    Bedfordshire
    44
    Alex-Nova396 is offline
    Afternoon guys and girls
    I'm in need of a bit of help if you guys would be so kind...
    I took the Chevy down to see Lance Mccormack about having some work done yesterday afternoon - I'll run another thread on that when the wheels set in motion...
    On the way back I pulled up at a set of lights, on dropping it into drive to pull off the car hesitated then just died.
    I have power, the battery is not dead as on turning the ignition on I get a healthy 14V, all the lights work, the fan starts up etc... so there is power, but on pressing the push start I get nothing, no noise, no click, no attempt to turn over, just nothing. so there doesn't seem to be any power going to the ignition.
    Not being a mechanic and just having minimal common knowledge on these things I'm left a bit stumped.
    Any help or advice would be greatly appreciated, any questions I'll try to answer as best I can!
    Sorry for the lack of info.
    South West Essex
    4,093
    14
    Roscobbc is offline
    Check out power to starter motor connection - this can loosen off. Same with battery connections and battery to earth and engine to earth strap. Check out connections to solenoid. Presumably the car is an auto - so haven't tried bump starting it?
    Nov 2013
    Bedfordshire
    44
    Quote Originally Posted by Roscobbc View Post
    Cheers. I'll get checking. Yeah it's a T350 tranny
    Nov 2011
    suffolk
    6,052
    1420
    russ6120 is online now
    Try starting in neutral as well as park. Might be inhibitor switch gone
    Nov 2013
    Bedfordshire
    44
    Quote Originally Posted by russ6120 View Post
    Tried that, no joy.
    Nov 2011
    suffolk
    6,052
    1420
    Might be time for a friendly auto electrician. Unless someone on here can talk you through it
    Gym Junkie chrisvs's Avatar
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    The fact that it stopped when put into drive and now will not start seems to point to the ignition circuitry, is it a column shift? maybe the action of putting it in drive has caused a cable to fall off/break on the ignition switch.
    Jan 2011
    Hitchin
    6,213
    125
    chrisvs is offline
    Found some wiring diagrams here if you need them:
    http://www.stevesnovasite.com/forums....php?p=2146761
    Nov 2013
    Bedfordshire
    44
    Cheers for the replies.
    After checking the connection to the started motor from the battery, squeezing me head under the car to get a look at the starter motor to changing the wires and a bit of head scratching it turned out to be what should of been checked first..... the fuse. Changed the fuse, problem solved. Why the fuse went is a different matter, but she's alive again.
    Thanks for wiring schematics Chris, that's gonna come in handy. My wiring is an absolute mess, the car seems to be have finished in a bit of a rush prior to shipping over here.
    Lower Kingswood, Surrey
    3,426
    185
    Mad Mark is offline
    Check all connections, as a loose connection can cause a high resistance and so draw more current, causing the fuse to blow.
    1. 64 nova
      By 62vette in forum The Showroom
      Last Post: 01-02-2012, 20:10
    2. Wanted for '66/'67 Chevy Nova, rear window
      By 440+6 in forum Stuff - WANTED
      Last Post: 23-10-2009, 17:48
    3. Rons Nova 1983...?
      By NoJive 55 in forum Tri Chevys, Spirit Of the Fifties and the Tuck Up Squad boys
      Last Post: 19-08-2009, 22:52
    4. Ultra Rare Dealer prep'd Nova
      By Stitch in forum On Topic
      Last Post: 28-04-2009, 18:55
    5. 67 chevy 11 - Nova brake shoes
      By stevie.t in forum Stuff - WANTED
      Last Post: 27-04-2009, 19:43
