Air ride leaf spring
Results 1 to 8 of 8
    Official RnS Addict fordf350camper's Avatar
    Jul 2009
    nottinghamshire
    737
    fordf350camper is offline
    Would it be possible to fit air ride to my Nissan trojan.The donor is the Nissan cabstar,Onthe front it has one big thick leaf spring that goes from the left side to the right side,Does the spring have to be removed.Any advice help is welcome thank you.If you dont know what my Trojan looks like look at my project thank you
    13,687
    if it's just the one leaf then you'd need to remove it, unless you want to 'lift' the front that is. i guess you could get it re rolled flatter to lower the car and use the bags to lift it to ride height, the advantage being you wouldn't need such big bags as they would be assisting the leaf not supporting the whole weight and it's still driveable (all be it low) if the bags failed.
    I'm a grown up member now ! Badgrizzly's Avatar
    Oct 2012
    hawkhurst kent
    99
    28
    Badgrizzly is offline
    So could you airbag a leaf sprung car, mine has front and rear semi elliptical springs. Could I reduce the amount of leaves and replace shocks with bags, the front springs have graphite sliders at the very front end rather than fixed in shackles, the rears have shackles. I currently have air shocks on the rear to allow small adjustment to ride height when loaded up. Oh its a 1949 AC.
    Cheers for any info G
    13,687
    Quote Originally Posted by Badgrizzly View Post
    you still need shocks, technically the bags are air springs not shocks. unless you get those spendy bag over shocks.
    but yes you can replace some leaves with bags to get ride height adjustment.
    Oct 2012
    hawkhurst kent
    99
    28
    Cheers Neil, will have a look to see what is out there re bags and best way to fit. Was not sure about the shocks bit so cheers. G
    Nov 2009
    Ol'fordshire
    2,978
    88
    JackGriffin is offline
    Although it could work, the remaining spring leaf(s) will be locating the axles under acceleration, braking and laterally during cornering so will need to be up to the job. For instance, if the rear springs were originally six leaves, if you use just the main leaf it could wind up under torque during acceleration and braking. Or you could add some form of traction control arms, panhard bars, etc.
    Screw EU
    13,687
    Quote Originally Posted by JackGriffin View Post
    good point, anti tramp bars are easy to fit though.
    Jul 2009
    nottinghamshire
    737
    Thank you
