Alloy wheel fitment
Results 1 to 7 of 7
    Jul 2010
    Hampshire
    413
    52
    truckdoctor is offline
    Alloy wheel fitment
    Not being an familiar with alloy wheels I could do with some technical information regarding these GKN alloys.
    I purchased a car and the wheels came with the car in boxes having been recently refurbished. Today when attempting a trial fit the nuts don't enter the holes due to the powder coating, simply not enough clearence, so what is the correct procedure now? machine the nuts down or clear out the powder coating from the holes, and how can it be done? And which is the face that the nuts locate too, the large one or the one in the bottom of the whole?
    Many thanks Steve
    Col
    Heavy Oiler Col's Avatar
    Feb 2010
    berks
    2,503
    299
    Col is offline
    Looks like you need tube nuts.
    https://www.rodsnsods.co.uk/forum/signaturepics/sigpic2162_1.gif Now off the road for body off rebuild. Will have blown bigblock & 5 spd gearbox.
    Rust buster...
    Sep 2011
    Wisbech
    602
    flak monkey is offline
    Looks like they should use these type of nuts:
    http://www.gambardellaracing.com/med...lug%20nuts.jpg
    They locate in the counterbores.
    Unless the bottom of the holes have the tapered seats for conventional nuts? Can't really tell from the pic.
    Either way the proper way would be to clean the powdercoat out of the holes
    Jan 2011
    harrogate
    301
    17
    pete cook is offline
    Hi Steve,you need tube nuts and washers or as the yanks call them lug nuts.The washers locate on the larger face and the machined part of the nut fits inside but does not contact on the base of the hole, hope this helps cheers Pete
    Jul 2010
    Hampshire
    413
    52
    Thanks Pete , I think you may be correct as I do have nuts that came with the wheels,and they look similar as the picture, just can't make out which surface holds the wheel, so if it's the large face I guess the powder coating needs to be removed from there and the hole.
    Jul 2010
    garden of England
    548
    27
    thisYup is offline
    they look like jensen interceptor wheels, so had sleeve nuts... ream out the hole to clear out the powder coating, it is thick! the nuts clamp the wheels on the outside, not the bottom of the hole, thats just to help you fit the wheels by aligning the stud with the centre of the hole
    this sort of thing...
    Jul 2010
    Hampshire
    413
    52
    Got it, thankyou.
    1. alloy wheels/tyres for the daily £90
      By 100ev8 in forum Stuff - FOR SALE
      Last Post: 25-02-2010, 18:34
    2. alloy wheel polishing
      By a40custom in forum On Topic
      Last Post: 02-01-2010, 20:15
    3. 7 x 15" alloy wheels Ford PCD
      By Blown 100e in forum Stuff - FOR SALE
      Last Post: 02-01-2010, 15:02
    4. What's the best primer for alloy wheels?
      By firebird68 in forum Tech Discussion
      Last Post: 31-10-2009, 13:19
    5. Steering wheel fitment
      By MUTANTV8 in forum Tech Discussion
      Last Post: 23-09-2009, 18:38
