Alternator charging "issues"
Results 1 to 8 of 8
    Rods 'n' Sods Junkie Hole Shot Pop's Avatar
    St Austell, Cornwall
    218
    Hole Shot Pop is offline
    Fired my engine up for the first time last night, which put a big smile on my face :-), so thanks for the wiring advice I've had here already. I have one more question though. I noticed that my red dash light for the alternator charging didn't go out when it was running. I took some pics of the alternator on my phone to try and identify it. It is a denso item, origin unknown, but it is like new so I took a gamble and used it. There are 3 pins at the back (photo's a bit crap). Can anyone suggest what the problem is?
    Thanks guys
    Mark
    Rods 'n' Sods Junkie smell my dog's Avatar
    Apr 2010
    worthing
    141
    15
    smell my dog is offline
    Re: Alternator charging "issues"
    First place i'd start is by checking its putting out a charge. Should be somewhere around 14 volts. Have you got a electrical meter?
    218
    Fair point, thanks. I do have one tucked away somewhere very safe :-/ i.e I will have to hunt for it. Just thinking out loud, because I'm not sure what it's from, I don't know how it would of been originally mounted, but I can't have it spinning the wrong way can I? It's spinning the same way whichever side of the engine its mounted to my way of thinking. Could it be a simple case of a poor earth through a freshly painted bracket? I did'nt have much time to check this last night-was too busy anxiously watching the temperature and oil pressure gauge haha. It ran well though apart from this glitch.
    Thanks
    Apr 2010
    worthing
    141
    15
    Anythings possible with electrics, i bloody hate them! But if you start at the source i.e. the alternator and thats ok the fix should get cheaper as you go along
    Apr 2010
    worthing
    141
    15
    One other thing, not sure if you have an internal or external regulator. If its external it might be worth a check.
    218
    Thanks, the regulator is internal.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Difficult to see, But that looks like the "three in row" style Denso socket. If it is, nearest the B terminal is the L contact for the warning light, middle is the IG that goes to the ignition switch, furthest from the B terminal is the S sensing connection, either connect this to the B terminal or to the IG terminal.
    Stuart.
    My Intro
    218
    You sir, are a legend! Thankyou. I will try that tonight.
  1. Wheels wanted - 15" 16" or 17" Ford 5 stud
    By telboyofpeckham in forum Stuff - WANTED
    Last Post: 10-05-2010, 07:49
  2. Wheels wanted - 15" 16" or 17" 5x4.5" PCD
    Last Post: 03-05-2010, 10:11
  3. Replies: 6
    Last Post: 29-11-2009, 13:15
  4. Replies: 0
    Last Post: 09-11-2009, 15:35
