Alternator wiring question
Results 1 to 5 of 5
    Rods 'n' Sods Junkie Hole Shot Pop's Avatar
    St Austell, Cornwall
    218
    Hole Shot Pop is offline
    Can someone please confirm the correct wiring for an alternator? My "understanding" is that the large terminal gets a permanent 12v feed. The smaller one gets an ignition feed, which goes through a dash warning light, which will go out when the alternator spins?
    Thanks guys
    Mark
    23,665
    Re: Alternator wiring question
    It's not actually the feed but output. That can go direct to battery but it is more usual to pick up at the starter solenoid, same terminal the battery connects to . You are correct power in to small terminal via light bulb on dash.
    "call 0-800 Apocalypse" satan's Avatar
    Nov 2009
    YOUR NIGHTMARES.
    5,229
    24
    satan is offline
    Quote Originally Posted by Hole Shot Pop View Post
    Thanks guys
    Mark
    basicly thats correct, there are a few things to consider,such as regulators can be internal or external, a resistor is used as well, the "large" terminal must be heavy guage wire and usually goes to the "hot" side of the starter, theres also a "one wire hookup" alternator, they normally come with a wiring dia, a quick google on the subject will tell ya loads of info. good luck.
    whoops too slow again,
    218
    Thanks for setting me straight on this guys. My alternator and starter are on different sides of the engine, so I think it would be neater to go straight to the battery for the "large" terminal ;-). The regulator is all contained inside, but the ignition feed terminal is actually 3 very small ones. Thanks guys, you've helped me out a lot
    Fruit & Nut Case great68's Avatar
    North London
    2,100
    334
    great68 is offline
    Don't forget a good earth strap from the engine block to the chassis, i have seen many fried shifter cables after being used to earth the starter.
    1. Wiper Motor Wiring Question
      Last Post: 01-04-2010, 19:33
    2. GM alternator
      By Plumpcars in forum Tech Discussion
      Last Post: 23-03-2010, 22:11
    3. Alternator
      By moosehead in forum Tech Discussion
      Last Post: 01-11-2009, 18:18
    4. 80s Firebird alternator wiring
      By zephyr in forum Tech Discussion
      Last Post: 01-10-2009, 16:32
    5. Alternator question
      By sidspop in forum Tech Discussion
      Last Post: 15-05-2009, 23:00
