Aluminium bodywork
Likes Likes:  1
Results 1 to 7 of 7
    Official RnS Addict 29stude's Avatar
    Nov 2009
    chesterfield/derbyshire/uk
    737
    567
    29stude is offline
    Aluminium bodywork
    Anyone tell me what is a suitable grade and thickness of aluminium for bodywork? Fabricating bonnet, scoop etc
    Found Several different types suggested on internet. Hoping someone on here has a definitive answer.
    Thanks Gav
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Not sure there is a definitive answer. I used 1050 sheet when I re-panelled the car in photo below. 1050 is pretty much pure aluminium. Normally comes as half hard, although you might want to anneal it if your doing work like the rivetted in bodywork "blister" in the pic below. Most of the bodywork on this car is 18 SWG (1.2mm), but 16 SWG (1.5mm) would be better if light weight isn't the most important thing.
    Stuart.
    My Intro
  4. LikesKustom Jim liked this post
  5. #3
    Herts
    4,591
    198
    WB54 is offline
    depends what you're doing when forming it. A thicker gauge is useful when stretching with a stretcher or English wheel, and when welding depending on your abilities. Thinner can be easier to shrink and easier to bead roll etc. Starting with half hard is the best bet but keep annealing it after each session forming.
    Where welding is concerned, i had a tough time welding formed panels where the edges had thinned, so I spent a lot of time blowing and fixing holes. If I were doing it again, I'd do a relatively cold butt weld on the inside first and fuse the outside with minimal /smaller rod , far less work in dressing the welds that way.
  6. Remove Advertisements
  7. #4
    Nov 2009
    737
    567
    29stude is offline
    Thank you both for info. I’ve just been to local steel merchant and got some 1.5 mm sheet: conveniently their stock seems to be mostly 1050 grade.
    Stuuee your car looks spot on, is the blister for throttle pedal clearance?
  8. #5
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Quote Originally Posted by 29stude View Post
    Yes, without that blister I would need to be wearing ballet pumps to be able to drive the car
    Stuart.
    My Intro
  9. #6
    Herts
    4,591
    198
    WB54 is offline
    I put a blister in the side panel on my car when we realised the starter motor didn't fit inside the chassis
  10. #7
    Nov 2009
    737
    567
    29stude is offline
    Nice motor . I’m going need blister for same reason as stueee and because they look cool, in a sort of form following function way.
    1. Replies: 9
      Last Post: 31-10-2010, 19:50
    2. Bodywork guys,
      By roofer in forum On Topic
      Last Post: 26-08-2009, 20:59
    3. Aluminium welding in Essex?
      By 30psi in forum On Topic
      Last Post: 23-06-2009, 12:29
    4. 2 1/4" Mains Aluminium Conrods
      By 30psi in forum Stuff - WANTED
      Last Post: 01-05-2009, 18:59
    5. Bodywork prices?
      By English Impala in forum On Topic
      Last Post: 25-04-2009, 18:56
