Another Fuel Tank Woe
Results 1 to 9 of 9
    Mar 2010
    Hemel Hempstead
    42
    littlecarl is offline
    I have a 1960 Dodge Station wagon. It's been a pain in the a**e to fill with fuel. I've had to fill it with jerry cans as the inlet pipe restricted the flow and either shut the pump off or I got covered in fuel. I knew it wasn't the original tank when I could only get about 8 gallons in it... Anyway I muddled on through filling a jerry can and pouring it in until I noticed it leaked fuel when it was over half full. So I decided to investigate.
    I removed the stone guard
    And got a free lump of wood.
    Here shows the bolt that was the leaky culprit. Shortly after it fell out!!
    This is the reason for the filling problems
    Pic from underneath the white light is where the filler neck goes. (fits from the outside)
    This is the only reference I have of what the tank should look like. Unfortunately I have no measurements and the void underneath is somewhat tricky to measure.
    I've been asking on the forward look forum and not had any joy there and wondered if any of you nice people have any suggestions?
    Ta
    Carl
    nottafukinchancingham
    8,020
    61
    Torment is offline
    modified mini fuel tank...????
    57 chevy wagon.
    540cui altered.
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    I think you were lucky you didn't have a major fire with that. Defies belief what some people consider to be an OK repair/modification.
    Presume you're going to want a tank with decent capacity, What about making your own tank out of Aluminium sheet to fit the space that's there? I've folded up fuel tanks for a couple of my cars using very simple tools. You can get someone else to do the welding if you don't have the right welding equipment.
    Stuart.
    My Intro
    13,792
    that's a mk1/2 escort saloon tank.
    Mar 2010
    Hemel Hempstead
    42
    I did wonder where that came from. Thanks I'll have to pull the rubber hose off the filler to check the escort cap went there.
    It should of been something I checked when I got the car. It wasn't on the road when I got it so wasn't as if the seller sold me a ticking time bomb and as it only had a gallon or two at a time it never leaked and being tucked under the car behind covers out of sight and mind....
    Yeah that should be quite a large tank fitted on there. I looked it up on 1991 BMW 850i Automatic
    and it should be a 83 liter / 21.9 U.S. gal / 18.2 imp. gal so quite a biggy. I may have to re mortgage to fill and test that baby when done lol.
    Stuart I've not built a tank before what type of ally and what thickness do you recommend making it from?
    I will have to make some sort of template maybe a cardboard tank (that might hold fuel better lol)
    Is there somewhere that can supply the filler neck to tank rubber seal?
    Cheers
    Carl
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Make the tank out of 1050 Aluminium; this is so-called half-hard pure Aluminium. You could use 5251 Aluminium alloy sheet, which is stronger but it's a sod to work. On a road car I use 1.5 mm thickness, you could use 1.2mm, but do you need to save a few ounces?
    Stuart.
    My Intro
    Nov 2010
    Rugby
    627
    48
    Jamie son of Old Dave is offline
    Quote Originally Posted by stueeee View Post
    1.2mm tends to warp a fair amount when welded too. Fortunately my tank has a big filler cap so I could give it a tap or two from the inside...
    Mar 2010
    Hemel Hempstead
    42
    No I don't think so.. A car that size a few ounces won't make any difference. Cheers
    Mar 2010
    Hemel Hempstead
    42
    I'll save a few more pounds by not filling it to the top......
    "I'm taking a shower now. Just slide her under the door!" - Moses Longpiece
  1. ally fuel tank
    By popleea in forum Tech Discussion
    Last Post: 21-07-2010, 16:53
  2. fuel tank cut and weld
    By nik347 in forum Tech Discussion
    Last Post: 23-08-2009, 08:57
  3. Ford 32b fuel tank
    By Jimbo in forum Stuff - WANTED
    Last Post: 05-07-2009, 17:49
  4. how to measure fuel tank for sender
    Last Post: 07-06-2009, 00:05
  5. plastic go kart fuel tank!
    By sqweaka in forum Stuff - FOR SALE
    Last Post: 26-04-2009, 09:03
