Any auto sparkies in da house?
Results 1 to 10 of 15
    Wareham, Dorset
    185
    yukonphil is offline
    Sea trials of my completed Suzuki X90 rebody are going well, apart from a tendancy for the battery to die if left for a few days. Brand new battery, terminals clean and tight, alternator light doesn't come on, only just started this morn but after a short run it has started several times since, nothing really in the system that could drain it that I'm aware of, no clock, no radio, she's as basic as they come. The only other factor worth mentioning is that I have relocated the battery to the boot. Any suggestions very welcome, thanks, Phil.
    23,737
    If yo have an AVOmeter it's quite simple to find out where the leak is .
    Remove your negative terminal and connect the AVO between battery and terminal . With everything switched off you shouldn't see a reading ( 12volt scale ) . Witha constatntly 'on' you will . Then pop round to your fuse box and pull a fuse at a time while watching the meter . When the AVO reads zero you now know which circuit is constantly live.
    Put the fuse back in and one by one pull off the live feed to each item on that circuit until the power goes off again . Then 'simply' find the fault.
    My money is on when you wired the relays for the wipers you wired the operating power direct from battery rather than from switched ignition . This would mean the relays are constantly engaged and will quickly ru your battery down...now why do I know that ?
    Wareham, Dorset
    185
    Thanks Kev, I'll try that tomorrow, is that just a multimeter you are referring to? Not too hopefull on the wipers though, I'm fairly sure they are wired to what was the heater as it had a nice fat supply wire BUT I do know that I can hear a relay click off when I disconnect the battery even with the ignition off so you may well be right. Have also got a killswitch in the system so am seeing if that works too but obviously want to find the fault. Thanks again.
    Jul 2010
    garden of England
    588
    27
    thisYup is offline
    a multimeter on current setting will do. put it on the 10A range to start with (just to save blowing a fuse in the multimeter until you know just how big the current draw is!) and monitor the current being drawn out of the battery.
    pull fuses til the current draw drops to nothing (as you have no radio or clock) then see whats downstream of the particular fuse...
    Wareham, Dorset
    185
    Quote Originally Posted by thisYup View Post
    It's a bit obvious once you've been told! Thanks chaps, got a feeling it will be sorted tomorrow, cracking forum this
    Wareham, Dorset
    185
    So, the relay that is on even with the ignition off is the hazard lights but I'm thinking this might be correct?
    I'm a grown up member now ! Mals32b's Avatar
    Sep 2017
    Whitworth
    42
    Mals32b is offline
    Quote Originally Posted by yukonphil View Post
    Disconnect that for now and see if the problem goes away.
    I have side lights and the hazards wired independently of the battery kill switch, so I can kill electrics and still have them working in the event of a failure on the roadside. I dont have a drain from the relay though (However i do have diodes fitted for other reasons which may help me)
    Mal
    Wareham, Dorset
    185
    Quote Originally Posted by Mals32b View Post
    Mal
    Yep, was thinking exactly that, will take the fuse out until I get the chance to check everything else. Very helpful comment about the sidelights too, that answers a question I didn't even ask, 10/10 on your mind reading abilities!
    Jul 2010
    garden of England
    588
    27
    thisYup is offline
    is the 'relay' the actual hazard flasher unit, or a relay feeding the hazard circuit....? not normally set up to have a relay permanently on cos, you know, it flattens the battery after a couple of days...
    Wareham, Dorset
    185
    Err, further to my earlier reply that I've just deleted, it would appear that I am in fact a complete idiot with a spectacular inability to count to 2 . Right, so the 'hazard' relay is actually the central locking relay which must be feeling awfully lonely in the loom since I chopped out all of it's associated wiring last Christmas, easiest thing to do now is leave the fuse out and see if that cures the problem. Many thanks for all the helpful post's. Anyone in the Wareham area that would like to pop round and knock some sense into me just drop me a PM
