Any transit experts around?? Delete if necessary as not a rod (but definately a sod.)
Results 1 to 10 of 44
    Oct 2013
    E.Sussex
    750
    380
    coupster is offline
    My transit has had difficulty in starting from cold, i thought glowplugs, but tested those and they are fine (besides apparantly the glowplugs on these are more to do with emmissions rather than for starting).
    This morning it took the same amount of turning over for it to get going, but once it was running, it was incredibly rough, not running on all cylinders, smoking, and sounded like a bag of nails at the top end of engine.
    Ive read that the timing chain tensioner can start to play up and make it hard to start from cold - im wondering if the tensioner has failed completely and now the timing is out...What else may i have broke.
    Its a 2006 2.4tddi 115
    Any help appreciated.
    Aug 2009
    braintree
    14,082
    69
    Darren West is offline
    i assume this is the last of the mk 6and rear wheel drive ?
    these suffer with air in the fuel system and usually its the filter head to blame
    what happens is that air gets in and the fuel starts to drain back to the tank
    a few questions please
    how many miles
    whats it like when its hot
    have you bump started it
    when did you last fit a diesel filter and was it a genuine one
    May 2010
    lichfield staffs
    4,451
    407
    streetfighter is offline
    if you have a noisy to end, its usually the chain tensioner problem, knocking timing out, they then smoke, miss and won't usually rev up properly. filterhead problem usually only affects starting and the 1st 10 minutes of running.
    Oct 2013
    E.Sussex
    750
    380
    coupster is offline
    Quote Originally Posted by Darren West View Post
    i assume this is the last of the mk 6and rear wheel drive ? Correct
    how many miles 108,000
    whats it like when its hot perfect (was until today)
    have you bump started it No cos it can **** them (which you obviously know)
    Fitted a new filter last week made no difference
    All good questions Darren, thanks, but i fear there is more of an issue, i hadnt ruled out changing the filter head but cant see the point now as its now running absolutely ****e so thinking must be more to it...
    edit, have answered your questions in the quote box, but not obvious, should have used another colour.
    Oct 2013
    E.Sussex
    750
    380
    coupster is offline
    Quote Originally Posted by streetfighter View Post
    MMmm thats my worry, wonder what else ive buggered up, then??
    May 2010
    lichfield staffs
    4,451
    407
    believe it or not, a chain kit usually fixes it. although, and don't discount this, i've done a couple that needed the cams re-tightening, because the chain moved that much that the valves were tapping the pistons. instead of bending the valves they lift the cams and loosen the carriers. if you have it code read, it should come up showing pump A timing error.
    Oct 2013
    E.Sussex
    750
    380
    coupster is offline
    Ah ok, thats helpful thanks, i suppose il take it apart and check the cam carrier and take chain cover off and see whats what....
    Is it a bitch of a job for a non trained mechanic do you think? Any special tools required?
    Any pointers would be great..
    Jul 2009
    three holes, wisbech, cambs
    5,158
    1001
    352 kum is offline
    put a di in it!
    Oct 2013
    E.Sussex
    750
    380
    coupster is offline
    Quote Originally Posted by 352 kum View Post
    put a di in it!
    Not a bad shout that!
    May 2010
    lichfield staffs
    4,451
    407
    is it fwd or rwd? what's the mileage?
    1. any rudge experts around
      By dutchrod in forum Chat
      Last Post: 04-11-2014, 17:23
    2. any ford flathead experts around Norwich
      By Kev F in forum Tech Discussion
      Last Post: 22-04-2013, 18:21
    3. Not a rod but Transit Jumbo Crew Cab - 2004 MK6 Diesel
      By foxcub1 in forum Vehicles - FOR SALE
      Last Post: 29-06-2011, 19:32
    4. Any Fiat experts
      Last Post: 28-05-2010, 17:54
    5. Any tax experts out there (company cars)?
      By English Impala in forum Chat
      Last Post: 29-12-2009, 10:15
