Anyone able to come and see engine running?
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Dec 2010
    Near Canning Town, London
    1,648
    1747
    Taxirod is offline
    (old pic)
    Its a 400 SBC with 6-71 blower.
    I just fitted a new crankshaft, while it was apart I had the rotating stuff balanced.
    The company doing the balancing work did not inspire confidence.
    Now its all back together, I'm convinced its way out of balance. Engine runs nicely, but terrible vibration, not so much at tickover, more as revs increase.
    Big dilemma - do i pull it all apart again and send off to a trustworthy company to check balancing?
    or could there be something I have missed.
    Its crunch time, but I dont wanna make wrong decision.
    Really would love someone to see it, hear it, and give your opinion.
    I'm happy to pay for your fuel / time etc.
    Thanks for reading
    Ian
    Herts
    4,580
    198
    WB54 is offline
    go with your gut feel, you know it ain't right, save yourself the agro and just pull it. Send it somewhere reputable but don't go telling them the history. See what they say balancing it afresh.
    Feb 2010
    Selby north yorks
    1,920
    127
    rodster is offline
    i would run it up with out the blower first and if its an auto don,t forget to recheck converter bolts
    12,690
    ian, for the time it'll take knock the 400 specific balance weight off of the flex plate and try it again. if it's not that just weld it back on when you take the motor out..... again. i've had it more than once, just saying.
    22,979
    Has it always had this imbalance ? Is the dizzy new and electronic ? Doe sit feel like an underlying growl ?
    Mar 2010
    Gone
    918
    13
    fall-apart-dave is offline
    A video might help folk with diagnosis? Then again a shakey engine is a shakey engine...
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Ian,
    This sounds well worth doing, just in case all that heavy metal inserted in the crank webs that you were telling me about last week has converted the crank to internal balance. if it is better without the flywheel weight, fit a neutral balance vibration damper and see if that improves it again.
    But if that does fix the problem, it certainly raises even bigger questions about the quality/competence of the balancing work.
    Stuart.
    My Intro
    6,176
    1026
    English Impala is offline
    I can offer no guidance whatsoever due to a medical condition that brings me out in a rash of stupidity whenever the internals of an engine need precision, BUT when I had my 302 internals balanced it was done with the entire assembly including the flex plate, the flex plate weight needed considerable lightening to balance it all.
    May 2010
    west yorks
    2,108
    68roadrunner is offline
    Quote Originally Posted by stueeee View Post
    Ian,
    If Mallory metal has been added to the counterweights, it HAS been internally balanced, you had better not use it if the dampner and flexplate/conv have weights on, it will twist the mains out of sync in the block or break the crank.
    I have this problem at the moment with a 900hp Dodge Ram, my friend has just had to import a £1500 McLeod twin plate clutch for it and we dont know if the fkn engine is IB or not as the engine has a K1 billet crank in it and was build on another Continent...right fkn pain to find out..grrr..LOL
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    Quote Originally Posted by 68roadrunner View Post
    You could well be right re the crank now being internal balance. There is a real long story behind this, which is Ian's place to tell (or not) But AFAIK, Ian provided the weighted flexplate and damper as well as the other bits for balancing. So it would be a bit bizarre if the guy has converted the crank to internal balance in the first place, even more bizarre to do that without converting the flexplate and damper to neutral balance at the same time. However, just because something is bizarre it doesn't mean it couldn't have happened
    Stuart.
    My Intro
    1. Come and see
      By Smokey in forum Chat
      Last Post: 02-01-2015, 21:17
    2. Anyone doing a tri chevy / ls1 engine swap
      By bash43 in forum Tri Chevys, Spirit Of the Fifties and the Tuck Up Squad boys
      Last Post: 07-05-2011, 13:34
    3. Replies: 6
      Last Post: 19-04-2011, 18:20
    4. Odds and ends. Please look and see if you can help!
      Last Post: 08-02-2011, 20:37
    5. Come and have a nose!
      By deadly in forum What, Where, When ?
      Last Post: 22-01-2011, 18:33
