Anyone know how to make a tube axle?
Results 1 to 7 of 7
    northumberland
    2,670
    sqweaka is offline
    anyone know the best way or tips on how to make atube front axle using mk1transit tubaxles? what thickness/size tube etc. any tech features on the subject?
    ian
    Aug 2009
    West mids, England.
    200
    King Herald is offline
    Quote Originally Posted by sqweaka View Post
    ian
    Ingredients:
    A length of 2" diameter seamless heavy wall steel tube, 3/8" wall thickness, or heavier.
    Two machined steel bosses the right size to take the kingpin bushes.
    Instructions:
    Mill the ends of the heavy tube out to accurately take the king pin bosses, camber angle etc.
    Weld prep these ends, 45 degrees by 1/4"
    Ask a qualified welder to weld the bosses in place.
    Add spring mounts or four bar mounts etc to suit your taste.
    Cook in a pre-warmed oven at 350C for 30 minutes (powder coating)
    Job done.
    Never make the mistake of thinking that the rut you're in is really a groove.
    S.E London
    5,717
    513
    vince-305 is offline
    What he said ^^^^^^
    But after a lot of research i have found that you can use 1.5" with .5 wall and do a lot or research first as steering can be quite awkward to sort afterwards (my own personal experience)
    Bit'z 'N' Piece's
    Jun 2009
    Rayleigh Essex
    3,185
    289
    trevd is offline
    as said above but if you have the transit axle its easy to use it as a welding fixture to ensure everything lines up correctly.
    Herts. and ahead of Larry :)
    2,630
    34
    chevy2 is offline
    As others have already stated regarding the wall thickness of the tube thickness, dont skimp on this,
    believe me, thin wall tube axles DO snap,
    Brian Arliss snapped one on his 32,
    luckily at slow speed, it was about 4mm? thick,
    new one was done in 3/8" wall tube.
    S.E London
    5,717
    513
    my axle is actually made from 40mm solid as i didnt know what thickness wall to go for
    It wasnt till after that i found that they use .5 (1/2") wall
    Bit'z 'N' Piece's
    Aug 2009
    West mids, England.
    200
    Quote Originally Posted by vince-305 View Post
    When you see the exhaust-pipe-type tube they build these little Locost type kit cars out of you realise just how skimpy you can get away with. I saw one at Donnington a few years ago, with A arm brackets bent from 16swg steel, held on with a single 6mm bolt. My buddy and I were gobsmacked just how feeble the whole thing looked, but they build hundreds of them, and they pass SVA and get used on the road and track all the time.
    Apparently.
    1. jago tube axle info...please
      Last Post: 16-04-2010, 21:50
    2. drop tube axle
      By TOETAG in forum Stuff - FOR SALE
      Last Post: 14-04-2010, 15:52
    3. Drop Tube Front Axle
      By v8 jago in forum Tech Discussion
      Last Post: 09-03-2010, 20:52
    4. straight tube axle
      By vin likes diesel in forum Stuff - WANTED
      Last Post: 17-08-2009, 09:24
    5. tube axle
      By neil harris in forum Stuff - FOR SALE
      Last Post: 06-07-2009, 19:27
