Auto C3 gearbox problems
Results 1 to 10 of 14
    Rods 'n' Sods Junkie Doubledoyle's Avatar
    Norwich
    332
    23
    Doubledoyle is offline
    Wonder if any of you guys can help me out, ive changed a c3 auto box because it has leaked oil and cooked reverse, The new box that went is was a so called low milage box, but ive now filled it up with oil and havent got any drive at all?
    Now im sure everything went in right, pretty sure the box wouldn't shut up if the torque convertor wasn't all the way home,
    Has anyone got any ideas to try before i take it all out again?
    wolverhampton
    1,392
    redvictor is offline
    Re: Auto C3 gearbox problems
    Are you sure you've checked the oil in park with the engine running? Next thing if it hasn't got rev or fwd then you'll have broken the pump gears fitting the trans on the engine.
    Europe's quickest and fastest street legal car. 4.09 @ 191 - 6.27 @ 237mph so far...
    IVA legal too!
    Penn Autos/Andy Frost race transmissions.
    www.redvictor1racing.co.uk
    Norwich
    332
    23
    Yep checked gear oil in neutral when running. is that right? also how would i have broken the pump gears fitting it, unfortunatley i dont know the history of the box, came with the car.
    wolverhampton
    1,392
    Quote Originally Posted by Doubledoyle View Post
    Neutral or park. When you fitted the trans did you push it against the engine and tighten the bolts by hand.Then did you check the converter by rattling it in it's holes (in the flexplate)to check it wasn't binding?
    IVA legal too!
    Norwich
    332
    23
    Hi andy thanks for your reply, well i tightened the torque convertor up before i done the bell housing, but to be completley honest i did find some resistance while turning the crank to get to the torque convertor bolts lined up in the starter, didn't really think about it at the time, can they brake this easy?
    Norwich
    332
    23
    oh and if thats is the case are they easy to change, ive still got the old box sitting here you see, could steal the pump gears if its possible?
    wolverhampton
    1,392
    Ah....Yes,they can break that easy.The gears are cast iron.
    You'll have to pull the trans out.Hopefully you've only broken the gears and not damaged the pump housing and torque converter.
    You should ALWAYS put the trans in by hand,tighten the bolts by hand whilst checking the converter is free. Any binding and you need to stop and find out why.Tightening the bolts on the trans without any of this always ends up in disaster..
    I always suggest to people to have a minimum of 2 doing this kind of job,preferably 3.
    Don't take it to heart. Just call it a lesson.I've known very good mechanics do the same thing. I get calls all the while. Hello,i've just fitted an engine/trans and got no drive...
    IVA legal too!
    Norwich
    332
    23
    Oh well, thats next week filled up then, thanks again for your advice, so do you think its possible to pull the gears out myself and switch with the other box i have?
    wolverhampton
    1,392
    On a C3 no.You need a tool to line the pump up to the bellhousing as there's no dowels.. If you know a machinist they can make you one. It has to fit in the pump bush tight and on the stator support tight to line them up properly
    Without it you can get pump whine from misalignment.
    IVA legal too!
    wolverhampton
    1,392
    i answered above but you could pull the bellhousing/pump assembly off and use it as a whole thing. Check for feed hole differences and bush sizes/ring pack depth but i'm pretty sure C3's had the same pump arrangment on all the models.
    Make sure as you're pulling it off that the direct/fwd clutch drums don't move or you'll need to pull it all apart. Hold the input shaft with the palm of your hand whilst pulling the bellhousing off. Use 2 people. You still might have trouble if the gasket sticks..
    IVA legal too!
    1. ford auto gearbox
      By maz5700 in forum Stuff - WANTED
      Last Post: 08-05-2010, 23:27
    2. Replies: 1
      Last Post: 04-05-2010, 13:24
    3. Sd1 or P6 V8 Auto gearbox
      By SteveW in forum Stuff - WANTED
      Last Post: 30-04-2010, 22:09
    4. Ford Sierra 4 speed auto Gearbox
      By Mr 440 in forum Stuff - FOR SALE
      Last Post: 01-01-2010, 15:12
    5. Auto Gearbox Specialist Recommendations? (SE)
      By daveyboy in forum Tech Discussion
      Last Post: 04-07-2009, 08:21
