Auto electrical advise needed
Results 1 to 10 of 15
    Cambridgeshire fens March area
    47
    6
    Classic is offline
    I need some way of getting a stand alone 2 watt bulb to illuminate for approximately 10 seconds when it is switched live by the ignition then go out, and not come on again until the next time it is switched live again. What type of relay or other means can I use?
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    Injection fuel pump relay when it pressurizes the injectors..
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    I think you could use this timer chip NE555N Timer : Timers : Maplin it should be OK with a 12V supply and the "falling voltage reset" facility should work when you turn off the ignition. Use the chip output via a PCB mount relay for the 2W bulb.
    Stuart.
    My Intro
    47
    6
    Classic is offline
    I'm a bit confused on this, I want it to come on when ign turned on then go out and stay out, and stay out until the next time the car is used again with the same result. What I am going to use it for is where the drivers air bag is removed and an after market steering wheel is used (no air bag)and the light will work as if the air bag is fitted, and the bulb holder is isolated from the air bag circuit (stand alone) The car has only a drivers air bag so no seat sensors
    47
    6
    Classic is offline
    Quote Originally Posted by paul67 View Post
    Does it switch its self off after app 10 secs and stay off untill used again?
    Feb 2011
    MIDDLESEX
    32
    GP200 is offline
    ...............I think the Ford Scorpios had a seat belt warning lamp that was controlled by a stand alone relay.........the warning lamp stayed on for 10/15 seconds...........possibly a route to go down..............
    12,800
    if its for the mot just take the bulb out. the airbag light being on all the time is not an mot failure so removing the bulb is not an issue.
    47
    6
    Classic is offline
    It will be after Jan 1st next year
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    As far as I was aware it is now ,and yes it does stay off till the next time you turn the ignition on,well mine does.And there must be a kit somewhere for what you want to do.
    Nov 2009
    stourport
    5,524
    7
    beach57 is offline
    This is not a simple fix,have just done some googling ,and the seat come's into play as there is a trigger sensor to tell when someone is in the seat.Check some forums as people are wanting to fit aftermarket seats for track days.
    1. Advise needed please
      By steadyg2002 in forum Chat
      Last Post: 03-11-2010, 18:52
    2. starting project, bit of advise needed
      By dutchrod in forum On Topic
      Last Post: 12-10-2010, 20:33
    3. Advise needed - hidden message?
      By 53catalina in forum Chat
      Last Post: 19-04-2010, 19:29
    4. Auto-electricians help needed: Towing electrics
      Last Post: 13-12-2009, 17:38
    5. help needed / rover auto conversion
      By farncombe pop in forum On Topic
      Last Post: 02-08-2009, 12:58
