Auto-electricians help needed: Towing electrics
Results 1 to 3 of 3
    6,271
    1043
    English Impala is offline
    My daily driver is a 2006 VW Passat 2.0 TDi estate. It has a towbar fitted with twin (12N/12S) electrics for towing a caravan. I fitted the towbar but had a towbar fitter do the electrics due to the low-current wiring requiring a special relay & probably a whole host of other wizardry that I couldn't do with a roll of insulating tape & a bag of scotch-locks. This was done when the car was new.
    I'm collecting a new caravan on Friday which has the new (continental style) 13 pin plug. I bought a 13 pin socket for the car & using a wiring diagram swapped the twin 12N/12S sockets for the new 13 pin socket and.... nothing. All I have got is 12V the ignition controlled pin everything else is dead. I have checked both fuses under the bonnet for the electrics (one for the fridge & one feeding the relay) and both are fine (but I changed them anyway "just in case"). Three of the pins have a permamnent low voltage reading of around 1V.
    I have had a look behind the trim panel & all of the wires seem okay, but the relay does smell (like a faint burnt PCB smell). Could this have burnt out, giving the symptoms above (including the low voltage to a few random pins)?
    Rods 'n' Sods Junkie englishedsel's Avatar
    Manchester
    124
    englishedsel is offline
    Sounds like the relay is burn't if you can smell it and the low voltage on the other pins. There is an adapter you can buy to convert the old style twin plugs to the new 13 pin plug. (Basically a fly lead with two plugs on one end and a 13 pin socket on the other) Any decent caravan shop should sell it if not they are available on flee-bay in the caravan accesories section. Not much help to you now I know but might be worth considering to convert back to original seeing as though it was working OK before.
    Rods 'n' Sods Junkie 100ev8's Avatar
    wolves
    437
    66
    100ev8 is offline
    you will need to buy the "specific loom" for it . new cars lights are tied in to ecu's and towbar wires play havoc with um !!!
    you can damage things by just conecting things up
    rob
    1. Replies: 32
      Last Post: 17-05-2010, 21:59
    2. Replies: 10
      Last Post: 18-04-2010, 13:46
    3. aa towing goes seriously wrong
      By stumpy in forum Chat
      Last Post: 09-12-2009, 00:22
    4. help needed / rover auto conversion
      By farncombe pop in forum On Topic
      Last Post: 02-08-2009, 11:58
    5. Electrics problem on my daily
      By Hemi Bucket in forum Tech Discussion
      Last Post: 17-05-2009, 19:01
