ballest resistor
Results 1 to 10 of 10
    Official RnS Addict Rustydicks's Avatar
    Mar 2011
    luton
    2,139
    535
    Rustydicks is offline
    ballest resistor
    hi guys
    can anyone tell me what resistance i should get across the ballast resistor i have a 12v coil
    on my model A
    the car starts but as soon as u let go of the key it cuts out ,
    it has power at the ignition switch and 12 v at the resistor
    hot wire it from the battery and it will run
    i have ordered another resistor
    thanks richard
    13,238
    a ballasted coil doesn't run on 12v. the ballast resistor cuts it down to summat like 9v for normal running but is bypassed on crank to give the 9v coil 12v for a hotter (temporary) spark when starting. the 9v going through the points makes them last longer as the spark there is smaller than if it was 12v.
    Mar 2011
    luton
    2,139
    535
    my dizzy doesn't have points do i still need a ballast resistor ?
    rich
    Official RnS Addict MikeS's Avatar
    Mar 2010
    Leighton Buzzard
    3,251
    207
    MikeS is offline
    If its a 9v coil then yes otherwise 12v will quickly burn out the coil. If you want to get going quickly then just change the 9v coil for a 12v one and bypass the resistor
    Mar 2011
    luton
    2,139
    535
    so if i have a 12v coil i do not need to have a resistor ?
    YamYam central
    3,489
    453
    74
    sidspop is offline
    No
    Official RnS Addict stu460's Avatar
    Jul 2011
    Cheshire
    1,789
    66
    stu460 is online now
    ^ that depends on what type of ignition module you are running. If you have a Mallory E-Spark or Unilite one in the dizzy then yes, this needs a 1.4 Ohm ballast resistor, feed it 12v and you'll kill it. Been there, got the T-shirt.
    kent
    2,960
    choppedblownpop is offline
    As above, Mallory/unilite you do need a ballast resistor
    Mar 2011
    luton
    2,139
    535
    cheap chinese dizzy
    YamYam central
    3,489
    453
    74
    sidspop is offline
    Measure the resistance of the ballast, you should have a few ohms. If no continuity it is goosed.
    It sounds to me more like you have lost the feed to the ballast. Check for a voltage at both ends, one end should come from ignition and be live with 12 volts, the other end about 9.
    If not 12 volts, get a separate wire from ignition and run it to top of ballast. From bottom of ballast is feed to coil. At that same bottom terminal (or terminal on coil) ensure there is a wire from starter motor that has 12volts on cranking.
    So possibilities are
    a) ********ed ballast
    b) dodgy wiring
    Any problems shout.
    Andy
    1. Rover V8 Hot Ballast Resistor.....WHY?
      By oldmanbass in forum Tech Discussion
      Last Post: 08-01-2012, 18:20
    2. ballast resistor
      By Frank Griffin47 in forum Tech Discussion
      Last Post: 03-04-2011, 22:17
    3. Replies: 6
      Last Post: 20-12-2010, 19:49
    4. Remove the ballast resistor ?
      By 34 boy in forum Tech Discussion
      Last Post: 25-06-2010, 20:52
    5. Resistor or not?
      By cabby in forum Tech Discussion
      Last Post: 01-07-2009, 09:22
