best bolt on brake upgrade for cortina mk 4
Results 1 to 5 of 5
    to much to do Andy Nineham's Avatar
    hants
    248
    21
    Andy Nineham is offline
    What would be the best calipers and rear drums etc that would bolt on to a Cortina mk4 any ideas please.
    Cheers Andy
    Rods 'n' Sods Junkie bandqpaul's Avatar
    Jan 2010
    epsom
    348
    52
    bandqpaul is offline
    Re: best bolt on brake upgrade for cortina mk 4
    Caprisport do all manner of upgrade kits for the fronts as they are a very similar set up,probably find the rear kits wil fit too
    23,216
    You planning on going THAT fast Andy ? I didn't think you drove like me !! I had stock Cortina front brakes on my 220bhp Rover powered blue APU and used it hard and they were fine.
    All the Ford front calipers use a 54mm piston so no more clamping pressure available from changing calipers . Drilled /crosscut discs will aid heat disappation and stop brake fade at speed.
    You can get a larger pad to suit the existing discs ,or upgraded material such as Green Stuff ( at a slight loss of slower braking capability ) .
    Next up is a vented disc so complete Granada upright and brake set up but at the downside of wider track , about 1-1.5 inches per side from memory.
    2 litre rear brakes have larger diameter and width though rear upgrades don't really yield huge improvement as under heavy breaking the weight is transferred to the front.
    Jan 2010
    epsom
    348
    52
    Thumbs upRe: best bolt on brake upgrade for cortina mk 4
    also capri vented discs will fit the front if you get a caliper spacing kit from rally design about £25
    Aug 2009
    Chatham
    336
    Avenger is offline
    Quote Originally Posted by bandqpaul View Post
    And they'll be just as crap as they are on a Capri! I'd be looking at Hi-spec's stuff if I needed to uprate Cortine brakes; assuming that RS turbo discs and calipers didn't fit under the wheels.
    Nick
    1. ******** Site Upgrade - BUG Report ********
      By Roadrunna in forum Announcements
      Last Post: 14-12-2010, 03:23
    2. GM 10 Bolt disc brake conversion?
      By Gotzy in forum Tech Discussion
      Last Post: 23-04-2010, 12:02
    3. 1960 Vauxhall velox brake upgrade...
      By Coppertop in forum Tech Discussion
      Last Post: 15-12-2009, 14:58
    4. chevy 10 bolt brake stuff
      By punk in forum Stuff - WANTED
      Last Post: 02-11-2009, 10:41
    5. Tube frame upgrade pics!
      By chevy2 in forum On Topic
      Last Post: 07-10-2009, 09:48
