Best engine for a 100e, Essex? Cologne? Zetec? please help
Results 1 to 8 of 8
    Jul 2010
    Bednall Stafford
    35
    4
    Flying Peach is offline
    Hello guys, I'm rodding for Ford Pop 100e, I've been thinking of an Essex v6 but heard some bad things about them eg weight etc, is a Cologne any better? what would you put in? I'm looking at simple and reliable but like the sound of a 'v' engine.
    Cheers
    Rods 'n' Sods Junkie steve_w's Avatar
    Apr 2010
    Hampshire
    454
    187
    steve_w is offline
    Quote Originally Posted by Flying Peach View Post
    Cheers
    Rover V8 heres mine
    Mar 2010
    northampton
    204
    9
    bilabong is offline
    Big block chevy ????
  5. #4
    Consett, Durham
    998
    8
    leepop633 is offline
    Big stonking V8, All depends on budget. If your thinking of a v6 then you might aswell go an extra 2 cylinders IMHO.
  6. #5
    Rod'a'holic rodbuilder's Avatar
    Glastonbury
    1,007
    721
    rodbuilder is offline
    200 sx turbo
  7. #6
    Nr. Dartford, Kent
    2,725
    244
    stueeee is offline
    IMO, For simplicity & reliability fit a 4 cylinder Zetec, plenty of good motors around, lots of parts available to adapt it to a type 9 five speed and sort the water manifolding etc., not so much power that a 105E axle (which is a bolt in job) wouldn't live. Essex V6 won't give a lot more power than a good Zetec, it's very heavy, and spares can't be so easy to get on what is now an old motor.
    Stuart.
    My Intro
  8. #7
    Jul 2009
    havant,hants
    440
    21
    paddy is offline
    The Cologne engine weighs roughly the same as an Essex V6.IMHO the 2.8 is a better engine and there's plenty of the about still.The problem is finding the earlier inlet manifolds that take a carb.I guess the injection system wouldn't be the end of the world to set up,they were pressure fed bosh systems.An xR4 would give you all the parts.At the end of the day they never went to bad did they, they're good old engines but there might well be a far better more modern option.
    If it bleeds, we can kill it.http://www.supermotors.net/21407
  9. #8
    North Yorkshire
    355
    25
    FlatheadFordV8 is offline
    There is also the Cosworth version of the Cologne V6 engine. 200 bhp, and said to be more economical than the 2.9L if you keep your foot off the loud pedal.
    Found in two forms, BOA in Granada Scorpio and BOB in the blob shaped Scorpio.
    BOA is the one to go for, as the ECU is not too complicated. They are all automatic, but you can fit a 2.9 flywheel and MT75 gearbox if you prefer manual. Watch out for timing chain problems. The BOB was slightly more powerful, but you can fit BOB cams to a BOA engine to give another 10 to 15 bhp. Granadas with orange indicators are non cat, and white are cat.
  1. ford v6 essex or cologne
    By bootlegger in forum Tech Discussion
    Last Post: 23-12-2011, 22:29
  2. 100e engine into model y
    By dek in forum Tech Discussion
    Last Post: 28-06-2010, 13:40
  3. 100e engine
    By Doug Jones in forum Stuff - WANTED
    Last Post: 19-05-2010, 22:03
  4. Ford 2.8 Cologne V6 Engine
    By caprijunkie in forum Stuff - FOR SALE
    Last Post: 26-04-2010, 19:03
  5. V6 Essex engine+bits
    By Gedney Rodder in forum Stuff - FOR SALE
    Last Post: 17-06-2009, 09:41
